address [tacacs+_server_IP_address]
0.0.0.0
Specifies the IP address or DNS name of the TACACS+ server. If you use DNS, ensure that DNS is configured and functional.
Defaultrole [a|u|o|c|r|s|Administrator|Operator]
Operator
Specifies the access role that is granted to all authenticated TACACS+ users.
This property supports the following legacy roles:
Administrator
Operator
Any individual role ID combinations where a = Admin, u = User Management, o = Operator, c = Console, r = Reset and Host Control, and s = Service.
fs_privilege [1|15]
1
Specifies the fs_privilege that is used for TACACS+ authenticated users to access and control SEFOS.
port [port_number]
49
Specifies the port number used to communicate with the TACACS+ server.
protocol
service
ip
ppp
protocol identifies the TACACS+ protocol type. service identifies the TACACS+ service type. (see footnote)
secret [tacacs+_secret]
[none]
Specifies the shared secret that is used to protect sensitive data and to ensure that the client and server recognize each other.
state [enabled|disabled]
Disabled
Specifies whether the TACACS+ client is enabled or disabled.
