Go to main content
Sun Network 10GbE Switch 72p Product Notes
Exit Print View
Updated: November 2016
Exclusive VLAN
In a traditional VLAN, the VLAN represents an L3 broadcast domain or a subnet. Exclusive VLAN (XVLAN) provides a discrete isolation of ports belonging to a traditional VLAN. Therefore, one host in an XVLAN can communicate with some of the hosts in the XVLAN, while another host cannot do the same even though they are in the same XVLAN and configured in the same subnet.
Refer to the Sun Ethernet Fabric Operating System XVLAN Administration Guide for more information about this feature. For information about supported XVLAN commands, refer to the Sun Ethernet Fabric Operating System CLI Base Reference Manual.
Note - See Changing the Default Value for default-vlan-id Could Result in VLAN Misconfiguration (7015004) for information about the required settings for default-vlan-id in XVLAN configurations.
