Skip Navigation Links
Exit Print View
Oracle Ethernet Switches
L2 and L3 Deployment Best Practices
search filter icon
search icon
Document Information
Using This Documention
Product Notes
Related Documentation
CLI Command Modes
Feedback
Support and Accessibility
Switches Overview
Oracle Switch ES1-24
Sun Network 10GbE Switch 72p
Sun Blade 6000 Ethernet Switched NEM 24p 10GbE
Understanding L2 and L3 Implementations
L2 and L3 Configuration Task Overview
L2 and L3 Topology
L2 and L3 VLAN Best Practices
Adding VLANs
Add an Untagged VLAN
Add a Tagged VLAN
L2 Based Configuration Example Using PVRST Protocol
L2 PVRST Example Overview
L2 PVRST Configuration Task Overview
Configuring a Basic L2 PVRST Based Topology
Configure Switch ToR72p-1 for L2 PVRST
Configure Switch ToR72p-2 for L2 PVRST
Configure Switch ES1-24p-1 for L2 PVRST
Configure Switch ES1-24p-2 for L2 PVRST
Verify the L2 PVRST Configuration
Configuring an L2 PVRST Based Topology With Active/Standby Bond on the Servers
Prepare Switch ToR72p-1 for L2 PVRST Active/Standby on the Servers
Prepare Switch ToR72p-2 for L2 PVRST Active/Standby on the Servers
Configure Switch ES1-24p-1 for L2 PVRST Active/Standby on the Servers
Configure Switch ES1-24p-2 for L2 PVRST Active/Standby on the Servers
Verify the L2 PVRST Active/Standby Configuration on the Servers
Configuring an L2 PVRST and LLA Based Topology With Active/Active Bond on the Servers
Configure Switch ES1-24p-1 for L2 PVRST LLA Active/Active on the Servers
Configure Switch ES1-24p-2 for L2 PVRST LLA Active/Active on the Servers
Configure Switch ToR72p-1 for L2 PVRST LLA Active/Active on the Servers
Configure Switch ToR72p-2 for L2 PVRST LLA Active/Active on the Servers
Verify the L2 PVRST LLA Active/Active Configuration on the Servers
L3 RIP and OSPF Configuration Overview
L3 Implementations Overview
L3 RIP and OSPF Configuration Task Overview
Configuring L3 Routing Based Topology Using RIP
Configure Switch TOR72p-1 for L3 Routing Using RIP
Configure Switch TOR72p-2 for L3 Routing Using RIP
Configure Switch ES1-24p-1 for L3 Routing Using RIP
Configure Switch ES1-24p-2 for L3 Routing Using RIP
Verify the L3 RIP Configuration
Configuring L3 Routing Based Topology Using OSPF
Configure Switch TOR72p-1 for L3 Routing Using OSPF
Configure Switch TOR72p-2 for L3 Routing Using OSPF
Configure Switch ES1-24p-1 for L3 Routing Using OSPF
Configure Switch ES1-24p-2 for L3 Routing Using OSPF
Verify the L3 OSPF Configuration
Glossary
Index
  1. Start the configuration with all ports and the default VLAN shutdown.
    Disable GVRP and GMRP.
    ES1-24p-2 SEFOS# configure terminal
    ES1-24p-2 SEFOS(config)# set gvrp disable
    ES1-24p-2 SEFOS(config)# set gmrp disable
    ES1-24p-2 SEFOS(config)# set port-channel enable
    ES1-24p-2 SEFOS(config)# interface vlan 1
    ES1-24p-2 SEFOS(config-if)# shutdown
    ES1-24p-2 SEFOS(config-if)# no ip address
    ES1-24p-2 SEFOS(config-if)# exit
    ES1-24p-2 SEFOS(config)# interface range extreme-ethernet 0/1-24
    ES1-24p-2 SEFOS(config-if-range)# shutdown
    ES1-24p-2 SEFOS(config-if-range)# end
  2. Create and enable port-channels between switches per the topology.
    See L2 and L3 Topology.
    ES1-24p-2 SEFOS(config)# interface port-channel 14
    ES1-24p-2 SEFOS(config-if)# no shutdown
    ES1-24p-2 SEFOS(config)# interface port-channel 15
    ES1-24p-2 SEFOS(config)# end
  3. Configure VLANs manually.
    You must add at least one port to the VLAN before you can assign the VLAN a name.
    Note - You can add VLANs as tagged or untagged to a port or a port-channel in three different ways. See Adding VLANs.
    ES1-24p-2 SEFOS(config)# vlan 2005
    ES1-24p-2 SEFOS(config-vlan)# ports add port-channel 14 untagged port-channel 14 name 192_168_205_0_RIP_P2P
    ES1-24p-2 SEFOS(config-vlan)# vlan active
    ES1-24p-2 SEFOS(config-vlan)# exit
    ES1-24p-2 SEFOS(config)# vlan 2006
    ES1-24p-2 SEFOS(config-vlan)# ports add port-channel 15 untagged port channel 15 name 192_168_206_0_RIP_P2P
    ES1-24p-2 SEFOS(config)# vlan 60
    ES1-24p-2 SEFOS(config-vlan)# ports add extreme-ethernet 0/1 untagged extreme-ethernet 0/1 name 192_168_60_0_HOST_P2P
  4. Configure the port-channels as access links by setting the pvid and adding port-channels to VLANs.
    Also, disable spanning-tree on all uplinks.
    ES1-24p-2 SEFOS(config-if)# switchport pvid 2005
    ES1-24p-2 SEFOS(config-if)# spanning-tree disable
    ES1-24p-2 SEFOS(config-if)# switchport pvid 2006
  5. Add the ports to the appropriate port-channels and enable the uplink interfaces to the aggregation switches.
    Configure the host port as an access link with a different VLAN.
    ES1-24p-2 SEFOS(config)# interface extreme-ethernet 0/1
    ES1-24p-2 SEFOS(config-if)# description "connected to eth1 nsn172-76"
    ES1-24p-2 SEFOS(config-if)# switchport pvid 60
    ES1-24p-2 SEFOS(config)# interface extreme-ethernet 0/23
    ES1-24p-2 SEFOS(config-if)# description "connected to ToR72p-1 on port68"
    ES1-24p-2 SEFOS(config-if)# channel-group 14 mode active
    ES1-24p-2 SEFOS(config)# interface extreme-ethernet 0/21
    ES1-24p-2 SEFOS(config-if)# description "connected to ToR72p-1 on port72"
    ES1-24p-2 SEFOS(config)# interface extreme-ethernet 0/24
    ES1-24p-2 SEFOS(config-if)# description "connected to ToR72p-2 on port67"
    ES1-24p-2 SEFOS(config-if)# channel-group 15 mode active
    ES1-24p-2 SEFOS(config)# interface extreme-ethernet 0/22
    ES1-24p-2 SEFOS(config-if)# description "connected to ToR72p-2 on port72"
  6. Configure the L3 interface for all VLANs defined previously.
    ES1-24p-2 SEFOS(config)# interface vlan 2005
    ES1-24p-2 SEFOS(config-if)# ip address 192.168.205.20 255.255.255.0
    ES1-24p-2 SEFOS(config)# interface vlan 2006
    ES1-24p-2 SEFOS(config-if)# ip address 192.168.206.20 255.255.255.0
    ES1-24p-2 SEFOS(config)# interface vlan 60
    ES1-24p-2 SEFOS(config-if)# ip address 192.168.60.10 255.255.255.0
  7. Enable RIP, and advertise the networks that are reachable through this switch.
    ES1-24p-2 SEFOS(config)# router rip
    ES1-24p-2 SEFOS(config-router)# version 2
    ES1-24p-2 SEFOS(config-router)# auto-summary disable
    ES1-24p-2 SEFOS(config-router)# redistribute connected
    ES1-24p-2 SEFOS(config-router)# network 192.168.205.20
    ES1-24p-2 SEFOS(config-router)# network 192.168.206.20
    ES1-24p-2 SEFOS(config-router)# network 192.168.60.10
    ES1-24p-2 SEFOS(config-router)# end
  8. Enable the VLANs to send and receive RIP version 2 updates.
    ES1-24p-2 SEFOS(config-if)# ip rip send version 2
    ES1-24p-2 SEFOS(config-if)# ip rip receive version 2
  9. Save the configuration.
    ES1-24p-2 SEFOS# copy run start
    Building configuration ...
    [OK]
    ES1-24p-2 SEFOS#
  10. Verify the status of the interfaces.
    ES1-24p-2 SEFOS# show interface description
    Interface    Status   Protocol  Description
    Ex0/1        up       up        connected to eth1 nsn172-76
    Ex0/2        down     down
    Ex0/20       down     down
    Ex0/21       up       up        connected to ToR72p-1 on port72
    Ex0/22       up       up        connected to ToR72p-2 on port72
    Ex0/23       up       up        connected to ToR72p-1 on port68
    Ex0/24       up       up        connected to ToR72p-2 on port67
    po14         up       up
    po15         up       up
    vlan1        down     down
    vlan2005     up       up
    vlan2006     up       up
    vlan60       up       up
  11. Verify the routes learned.
    ES1-24p-2 SEFOS# show ip route
    Codes: C - connected, S - static, R - rip, B - bgp, O - ospf
    R 192.168.9.0/24 [3] via 192.168.205.10
    R 192.168.20.0/24 [3] via 192.168.205.10
    R 192.168.30.0/24 [2] via 192.168.205.10
    R 192.168.40.0/24 [4] via 192.168.205.10
    R 192.168.50.0/24 [3] via 192.168.205.10
    C 192.168.60.0/24 is directly connected, vlan60
    R 192.168.100.0/24 [3] via 192.168.205.10
    R 192.168.101.0/24 [3] via 192.168.205.10
    R 192.168.150.0/24 [3] via 192.168.205.10
    R 192.168.151.0/24 [3] via 192.168.205.10
    R 192.168.201.0/24 [2] via 192.168.205.10
    R 192.168.202.0/24 [3] via 192.168.205.10
    R 192.168.203.0/24 [2] via 192.168.205.10
    R 192.168.204.0/24 [3] via 192.168.205.10
    C 192.168.205.0/24 is directly connected, vlan2005
    C 192.168.206.0/24 is directly connected, vlan2006
    R 192.168.205.0/24 [2] via 192.168.203.10
    R 192.168.206.0/24 [3] via 192.168.203.10
    R 45.45.45.0/24 [3] via 192.168.205.10
    R 45.45.46.0/24 [3] via 192.168.205.10
    R 45.45.47.0/24 [3] via 192.168.205.10
    R 45.45.48.0/24 [3] via 192.168.205.10
    R 45.45.49.0/24 [3] via 192.168.205.10
    R 45.45.50.0/24 [3] via 192.168.205.10
    R 45.45.51.0/24 [3] via 192.168.205.10
  12. Verify the number of routes.
    After IXIA sends 500 routes to the core switch, those routes are learned on this switch.
    ES1-24p-2 SEFOS# show ip route summary
    Route Source    Routes
    connected         3
    static            0
    rip               513
    bgp               0
    ospf              0
    Total             516
Related Information
