Sun Blade 6000 Ethernet Switched NEM 24p 10GbE
Understanding L2 and L3 Implementations
L2 and L3 Configuration Task Overview
L2 Based Configuration Example Using PVRST Protocol
L2 PVRST Configuration Task Overview
Configuring a Basic L2 PVRST Based Topology
Configure Switch ToR72p-1 for L2 PVRST
Configure Switch ToR72p-2 for L2 PVRST
Configure Switch ES1-24p-1 for L2 PVRST
Configure Switch ES1-24p-2 for L2 PVRST
Verify the L2 PVRST Configuration
Configuring an L2 PVRST Based Topology With Active/Standby Bond on the Servers
Prepare Switch ToR72p-1 for L2 PVRST Active/Standby on the Servers
Prepare Switch ToR72p-2 for L2 PVRST Active/Standby on the Servers
Configure Switch ES1-24p-1 for L2 PVRST Active/Standby on the Servers
Configure Switch ES1-24p-2 for L2 PVRST Active/Standby on the Servers
Configuring an L2 PVRST and LLA Based Topology With Active/Active Bond on the Servers
Configure Switch ES1-24p-1 for L2 PVRST LLA Active/Active on the Servers
Configure Switch ES1-24p-2 for L2 PVRST LLA Active/Active on the Servers
Configure Switch ToR72p-1 for L2 PVRST LLA Active/Active on the Servers
Configure Switch ToR72p-2 for L2 PVRST LLA Active/Active on the Servers
Verify the L2 PVRST LLA Active/Active Configuration on the Servers
L3 RIP and OSPF Configuration Overview
L3 RIP and OSPF Configuration Task Overview
Configuring L3 Routing Based Topology Using RIP
Configure Switch TOR72p-1 for L3 Routing Using RIP
Configure Switch TOR72p-2 for L3 Routing Using RIP
Configure Switch ES1-24p-1 for L3 Routing Using RIP
Configure Switch ES1-24p-2 for L3 Routing Using RIP
Verify the L3 RIP Configuration
Configuring L3 Routing Based Topology Using OSPF
Configure Switch TOR72p-1 for L3 Routing Using OSPF
Configure Switch TOR72p-2 for L3 Routing Using OSPF
Configure Switch ES1-24p-1 for L3 Routing Using OSPF
Configure Switch ES1-24p-2 for L3 Routing Using OSPF
Note - All pings should be successful.
Host-6 has a bond to test the Active/Standby configuration.
[Host-6 ~]# ifconfig bond0 Link encap:Ethernet HWaddr 00:10:E0:22:0F:D9 inet addr:192.168.99.25 Bcast:192.168.99.255 Mask:255.255.255.0 inet6 addr: fe80::210:e0ff:fe22:fd9/64 Scope:Link UP BROADCAST RUNNING MASTER MULTICAST MTU:1500 Metric:1 RX packets:73 errors:0 dropped:0 overruns:0 frame:0 TX packets:151 errors:0 dropped:0 overruns:0 carrier:0 collisions:0 txqueuelen:0 RX bytes:9490 (9.2 KiB) TX bytes:18909 (18.4 KiB) bond0.200 Link encap:Ethernet HWaddr 00:10:E0:22:0F:D9 inet addr:192.168.20.25 Bcast:192.168.20.255 Mask:255.255.255.0 inet6 addr: fe80::210:e0ff:fe22:fd9/64 Scope:Link ... bond0.201 Link encap:Ethernet HWaddr 00:10:E0:22:0F:D9 inet addr:192.168.21.25 Bcast:192.168.21.255 Mask:255.255.255.0 inet6 addr: fe80::210:e0ff:fe22:fd9/64 Scope:Link ... bond0.202 Link encap:Ethernet HWaddr 00:10:E0:22:0F:D9 inet addr:192.168.22.25 Bcast:192.168.22.255 Mask:255.255.255.0 inet6 addr: fe80::210:e0ff:fe22:fd9/64 Scope:Link ... bond0.203 Link encap:Ethernet HWaddr 00:10:E0:22:0F:D9 inet addr:192.168.23.25 Bcast:192.168.23.255 Mask:255.255.255.0 inet6 addr: fe80::210:e0ff:fe22:fd9/64 Scope:Link ... bond0.300 Link encap:Ethernet HWaddr 00:10:E0:22:0F:D9 inet addr:192.168.30.25 Bcast:192.168.30.255 Mask:255.255.255.0 inet6 addr: fe80::210:e0ff:fe22:fd9/64 Scope:Link ... bond0.301 Link encap:Ethernet HWaddr 00:10:E0:22:0F:D9 inet addr:192.168.31.25 Bcast:192.168.31.255 Mask:255.255.255.0 inet6 addr: fe80::210:e0ff:fe22:fd9/64 Scope:Link ... bond0.302 Link encap:Ethernet HWaddr 00:10:E0:22:0F:D9 inet addr:192.168.32.25 Bcast:192.168.32.255 Mask:255.255.255.0 inet6 addr: fe80::210:e0ff:fe22:fd9/64 Scope:Link ... bond0.303 Link encap:Ethernet HWaddr 00:10:E0:22:0F:D9 inet addr:192.168.33.25 Bcast:192.168.33.255 Mask:255.255.255.0 inet6 addr: fe80::210:e0ff:fe22:fd9/64 Scope:Link ... eth1 Link encap:Ethernet HWaddr 00:10:E0:22:0F:D9 ... eth6 Link encap:Ethernet HWaddr 00:10:E0:22:0F:D9 ...
[Host-2 ~]# ifconfig -a nxge1: flags=1001000843<UP,BROADCAST,RUNNING,MULTICAST,IPv4,FIXEDMTU> mtu 9000 index 4 inet 192.168.99.15 netmask ffffff00 broadcast 192.168.99.255 ether 0:14:4f:6c:43:9 nxge200001: flags=201000843<UP,BROADCAST,RUNNING,MULTICAST,IPv4,CoS> mtu 9194 index 6 inet 192.168.20.15 netmask ffffff00 broadcast 192.168.20.255 ether 0:14:4f:6c:43:9 nxge201001: flags=201000843<UP,BROADCAST,RUNNING,MULTICAST,IPv4,CoS> mtu 9194 index 7 inet 192.168.21.15 netmask ffffff00 broadcast 192.168.21.255 ether 0:14:4f:6c:43:9 nxge202001: flags=201000843<UP,BROADCAST,RUNNING,MULTICAST,IPv4,CoS> mtu 9194 index 8 inet 192.168.22.15 netmask ffffff00 broadcast 192.168.22.255 ether 0:14:4f:6c:43:9 nxge203001: flags=201000843<UP,BROADCAST,RUNNING,MULTICAST,IPv4,CoS> mtu 9194 index 9 inet 192.168.23.15 netmask ffffff00 broadcast 192.168.23.255 ether 0:14:4f:6c:43:9 nxge300001: flags=201000843<UP,BROADCAST,RUNNING,MULTICAST,IPv4,CoS> mtu 9194 index 10 inet 192.168.30.15 netmask ffffff00 broadcast 192.168.30.255 ether 0:14:4f:6c:43:9 nxge301001: flags=201000843<UP,BROADCAST,RUNNING,MULTICAST,IPv4,CoS> mtu 9194 index 11 inet 192.168.31.15 netmask ffffff00 broadcast 192.168.31.255 ether 0:14:4f:6c:43:9 nxge302001: flags=201000843<UP,BROADCAST,RUNNING,MULTICAST,IPv4,CoS> mtu 9194 index 12 inet 192.168.32.15 netmask ffffff00 broadcast 192.168.32.255 ether 0:14:4f:6c:43:9 nxge303001: flags=201000843<UP,BROADCAST,RUNNING,MULTICAST,IPv4,CoS> mtu 9194 index 13 inet 192.168.33.15 netmask ffffff00 broadcast 192.168.33.255 ether 0:14:4f:6c:43:9
[Host-1 ~]# ifconfig
eth3 Link encap:Ethernet HWaddr 00:10:E0:1F:BD:E3 inet addr:192.168.99.10 Bcast:192.168.99.255
Mask:255.255.255.0 inet6 addr: fe80::210:e0ff:fe1f:bde3/64 Scope:Link UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1 RX packets:734694172 errors:0 dropped:229967577 overruns:0
frame:0 TX packets:408889295 errors:0 dropped:0 overruns:0
carrier:0 collisions:0 txqueuelen:1000 RX bytes:48601478150 (45.2 GiB) TX bytes:17173383292
(15.9 GiB)
eth3.300 Link encap:Ethernet HWaddr 00:10:E0:1F:BD:E3 inet addr:192.168.30.10 Bcast:192.168.30.255
eth3.301 Link encap:Ethernet HWaddr 00:10:E0:1F:BD:E3 inet addr:192.168.31.10 Bcast:192.168.31.255
eth3.302 Link encap:Ethernet HWaddr 00:10:E0:1F:BD:E3 inet addr:192.168.32.10 Bcast:192.168.32.255
eth3.303 Link encap:Ethernet HWaddr 00:10:E0:1F:BD:E3 inet addr:192.168.33.10 Bcast:192.168.33.255
...[Host-6 ~]# cat /proc/net/bonding/bond0 Ethernet Channel Bonding Driver: v3.6.0 (September 26, 2009) Bonding Mode: fault-tolerance (active-backup)Primary Slave: eth1 (primary_reselect always)Currently Active Slave: eth1MII Status: up MII Polling Interval (ms): 100Up Delay (ms): 0Down Delay (ms): 0 Slave Interface: eth1MII Status: upLink Failure Count: 1 Permanent HW addr: 00:10:e0:22:0f:d9Slave queue ID: 0 Slave Interface: eth6MII Status: up Link Failure Count: 1Permanent HW addr: 00:10:e0:22:0f:da Slave queue ID: 0
[Host-6 ~]# ping 192.168.99.10
[Host-6 ~]# ping 192.168.33.10 [Host-6 ~]# ping 192.168.30.10
[Host-1 ~]# ping 192.168.33.25 [Host-2 ~]# ping -s 192.168.20.25
