Sun Blade 6000 Ethernet Switched NEM 24p 10GbE
Understanding L2 and L3 Implementations
L2 and L3 Configuration Task Overview
L2 Based Configuration Example Using PVRST Protocol
L2 PVRST Configuration Task Overview
Configuring a Basic L2 PVRST Based Topology
Configure Switch ToR72p-1 for L2 PVRST
Configure Switch ToR72p-2 for L2 PVRST
Configure Switch ES1-24p-1 for L2 PVRST
Configure Switch ES1-24p-2 for L2 PVRST
Verify the L2 PVRST Configuration
Configuring an L2 PVRST Based Topology With Active/Standby Bond on the Servers
Prepare Switch ToR72p-1 for L2 PVRST Active/Standby on the Servers
Prepare Switch ToR72p-2 for L2 PVRST Active/Standby on the Servers
Configure Switch ES1-24p-2 for L2 PVRST Active/Standby on the Servers
Verify the L2 PVRST Active/Standby Configuration on the Servers
Configuring an L2 PVRST and LLA Based Topology With Active/Active Bond on the Servers
Configure Switch ES1-24p-1 for L2 PVRST LLA Active/Active on the Servers
Configure Switch ES1-24p-2 for L2 PVRST LLA Active/Active on the Servers
Configure Switch ToR72p-1 for L2 PVRST LLA Active/Active on the Servers
Configure Switch ToR72p-2 for L2 PVRST LLA Active/Active on the Servers
Verify the L2 PVRST LLA Active/Active Configuration on the Servers
L3 RIP and OSPF Configuration Overview
L3 RIP and OSPF Configuration Task Overview
Configuring L3 Routing Based Topology Using RIP
Configure Switch TOR72p-1 for L3 Routing Using RIP
Configure Switch TOR72p-2 for L3 Routing Using RIP
Configure Switch ES1-24p-1 for L3 Routing Using RIP
Configure Switch ES1-24p-2 for L3 Routing Using RIP
Verify the L3 RIP Configuration
Configuring L3 Routing Based Topology Using OSPF
Configure Switch TOR72p-1 for L3 Routing Using OSPF
Configure Switch TOR72p-2 for L3 Routing Using OSPF
Configure Switch ES1-24p-1 for L3 Routing Using OSPF
Configure Switch ES1-24p-2 for L3 Routing Using OSPF
Tip - It is a best practice to start the configuration with all the ports and default VLAN shutdown. Disable GVRP and GMRP because dynamic VLAN learning is not suggested.
ES1-24p-1 SEFOS# configure terminal ES1-24p-1 SEFOS(config)# set gvrp disable ES1-24p-1 SEFOS(config)# set gmrp disable ES1-24p-1 SEFOS(config)# set port-channel enable ES1-24p-1 SEFOS(config)# interface vlan 1 ES1-24p-1 SEFOS(config-if)# shutdown ES1-24p-1 SEFOS(config-if)# no ip address ES1-24p-1 SEFOS(config-if)# exit ES1-24p-1 SEFOS(config)# interface range extreme-ethernet 0/1-24 ES1-24p-1 SEFOS(config-if-range)# shutdown ES1-24p-1 SEFOS(config-if-range)# end
See L2 and L3 Topology.
ES1-24p-1 SEFOS# configure terminal ES1-24p-1 SEFOS(config)# interface port-channel 12 ES1-24p-1 SEFOS(config-if)# no shutdown ES1-24p-1 SEFOS(config-if)# exit ES1-24p-1 SEFOS(config)# interface port-channel 13 ES1-24p-1 SEFOS(config-if)# no shutdown ES1-24p-1 SEFOS(config-if)# exit ES1-24p-1 SEFOS(config)# interface port-channel 100 ES1-24p-1 SEFOS(config-if)# no shutdown ES1-24p-1 SEFOS(config-if)# exit ES1-24p-1 SEFOS(config)# end
You must add at least one port to the VLAN before you can assign the VLAN a name.
ES1-24p-1 SEFOS# configure terminal ES1-24p-1 SEFOS(config)# vlan 300 ES1-24p-1 SEFOS(config-vlan)# ports add extreme-ethernet 0/2 name external-vlan-1 ES1-24p-1 SEFOS(config-vlan)# vlan active ES1-24p-1 SEFOS(config-vlan)# exit ES1-24p-1 SEFOS(config)# vlan 301 ES1-24p-1 SEFOS(config-vlan)# ports add extreme-ethernet 0/2 name external-vlan-2 ES1-24p-1 SEFOS(config-vlan)# vlan active ES1-24p-1 SEFOS(config-vlan)# exit ES1-24p-1 SEFOS(config)# vlan 302 ES1-24p-1 SEFOS(config-vlan)# ports add extreme-ethernet 0/2 name external-vlan-3 ES1-24p-1 SEFOS(config-vlan)# vlan active ES1-24p-1 SEFOS(config-vlan)# exit ES1-24p-1 SEFOS(config)# vlan 303 ES1-24p-1 SEFOS(config-vlan)# ports add extreme-ethernet 0/2 name external-vlan-4 ES1-24p-1 SEFOS(config-vlan)# vlan active ES1-24p-1 SEFOS(config-vlan)# exit ES1-24p-1 SEFOS(config)# vlan 200 ES1-24p-1 SEFOS(config-vlan)# ports add extreme-ethernet 0/2 name internal-vlan-1 ES1-24p-1 SEFOS(config-vlan)# vlan active ES1-24p-1 SEFOS(config-vlan)# exit ES1-24p-1 SEFOS(config)# vlan 201 ES1-24p-1 SEFOS(config-vlan)# ports add extreme-ethernet 0/2 name internal-vlan-2 ES1-24p-1 SEFOS(config-vlan)# vlan active ES1-24p-1 SEFOS(config-vlan)# exit ES1-24p-1 SEFOS(config)# vlan 202 ES1-24p-1 SEFOS(config-vlan)# ports add extreme-ethernet 0/2 name internal-vlan-3 ES1-24p-1 SEFOS(config-vlan)# vlan active ES1-24p-1 SEFOS(config-vlan)# exit ES1-24p-1 SEFOS(config)# vlan 203 ES1-24p-1 SEFOS(config-vlan)# ports add extreme-ethernet 0/1 name internal-vlan-4 ES1-24p-1 SEFOS(config-vlan)# vlan active ES1-24p-1 SEFOS(config-vlan)# exit ES1-24p-1 SEFOS(config)# end
ES1-24p-1 SEFOS# configure terminal ES1-24p-1 SEFOS(config)# interface port-channel 12 ES1-24p-1 SEFOS(config-if)# switchport mode trunk ES1-24p-1 SEFOS(config-if)# exit ES1-24p-1 SEFOS(config)# interface port-channel 13 ES1-24p-1 SEFOS(config-if)# switchport mode trunk ES1-24p-1 SEFOS(config-if)# exit ES1-24p-1 SEFOS(config)# interface port-channel 100 ES1-24p-1 SEFOS(config-if)# switchport mode trunk ES1-24p-1 SEFOS(config-if)# exit ES1-24p-1 SEFOS(config)# end
Configure the host port to allow all VLANs.
ES1-24p-1 SEFOS# configure terminal ES1-24p-1 SEFOS(config)# interface extreme-ethernet 0/2 ES1-24p-1 SEFOS(config-if)# description "connected to eth1 Host-6, bond0" ES1-24p-1 SEFOS(config-if)# switchport mode trunk ES1-24p-1 SEFOS(config-if)# no shutdown ES1-24p-1 SEFOS(config-if)# exit ES1-24p-1 SEFOS(config)# interface range extreme-ethernet 0/19-20 ES1-24p-1 SEFOS(config-if)# description "connected to ES1-24p-2 on ports 19-20" ES1-24p-1 SEFOS(config-if)# channel-group 100 mode on ES1-24p-1 SEFOS(config-if)# no shutdown ES1-24p-1 SEFOS(config-if)# exit ES1-24p-1 SEFOS(config)# interface extreme-ethernet 0/23 ES1-24p-1 SEFOS(config-if)# description "connected to ToR72p-1 on port67" ES1-24p-1 SEFOS(config-if)# channel-group 12 mode active ES1-24p-1 SEFOS(config-if)# no shutdown ES1-24p-1 SEFOS(config-if)# exit ES1-24p-1 SEFOS(config)# interface extreme-ethernet 0/21 ES1-24p-1 SEFOS(config-if)# description "connected to ToR72p-1 on port71" ES1-24p-1 SEFOS(config-if)# channel-group 12 mode active ES1-24p-1 SEFOS(config-if)# no shutdown ES1-24p-1 SEFOS(config-if)# exit ES1-24p-1 SEFOS(config)# interface extreme-ethernet 0/24 ES1-24p-1 SEFOS(config-if)# description "connected to ToR72p-2 on port68" ES1-24p-1 SEFOS(config-if)# channel-group 13 mode active ES1-24p-1 SEFOS(config-if)# no shutdown ES1-24p-1 SEFOS(config-if)# exit ES1-24p-1 SEFOS(config)# interface extreme-ethernet 0/22 ES1-24p-1 SEFOS(config-if)# description "connected to ToR72p-2 on port71" ES1-24p-1 SEFOS(config-if)# channel-group 13 mode active ES1-24p-1 SEFOS(config-if)# no shutdown ES1-24p-1 SEFOS(config-if)# exit ES1-24p-1 SEFOS(config)# end
ES1-24p-1 SEFOS# configure terminal ES1-24p-1 SEFOS(config)# spanning-tree mode pvrst Spanning Tree enabled protocol is MSTP, now MSTP is being shutdown PVRST is started. PVRST Module status is changed ES1-24p-1 SEFOS(config)# spanning-tree vlan 200 brg-priority 61440 ES1-24p-1 SEFOS(config)# spanning-tree vlan 201 brg-priority 61440 ES1-24p-1 SEFOS(config)# spanning-tree vlan 202 brg-priority 61440 ES1-24p-1 SEFOS(config)# spanning-tree vlan 203 brg-priority 61440 ES1-24p-1 SEFOS(config)# spanning-tree vlan 300 brg-priority 40960 ES1-24p-1 SEFOS(config)# spanning-tree vlan 301 brg-priority 40960 ES1-24p-1 SEFOS(config)# spanning-tree vlan 302 brg-priority 40960 ES1-24p-1 SEFOS(config)# spanning-tree vlan 303 brg-priority 40960 ES1-24p-1 SEFOS(config)# spanning-tree vlan 1 brg-priority 40960 ES1-24p-1 SEFOS(config)# end
ES1-24p-1 SEFOS# copy run start Building configuration ... [OK] ES1-24p-1 SEFOS#
ES1-24p-1 SEFOS# show spanning-tree Spanning-tree for VLAN 200 Root Id Priority 8392 Address 00:21:28:77:d2:1d Cost 1900 Port po12 Hello Time 2 Sec, Max Age 20 Sec, Forward Delay 15 Sec Spanning Tree Enabled Protocol PVRST Bridge Id Priority 61640 Address 00:10:e0:2c:0f:21 Hello Time 2 sec, Max Age 20 sec, Forward Delay 15 sec Dynamic Path Cost is Disabled Dynamic Path Cost Lag-Speed Change is Disabled Name Role State Cost Prio Type ---- ---- ----- ---- ---- ------ Ex0/2 Designated Forwarding 2000 128 P2P po12 Root Forwarding 1900 128 P2P po13 Designated Forwarding 1900 128 P2P po100 Alternate Discarding 1900 128 P2P ... Spanning-tree for VLAN 302 Root Id Priority 4096 Address 00:17:df:18:9d:2e Cost 21800 Port po12 Hello Time 2 Sec, Max Age 20 Sec, Forward Delay 15 Sec Spanning Tree Enabled Protocol PVRST Bridge Id Priority 61742 Address 00:10:e0:2c:0f:21 Hello Time 2 sec, Max Age 20 sec, Forward Delay 15 sec Dynamic Path Cost is Disabled Dynamic Path Cost Lag-Speed Change is Disabled Name Role State Cost Prio Type ---- ---- ----- ---- ---- ------ Ex0/2 Designated Forwarding 2000 128 P2P po12 Root Forwarding 1900 128 P2P po13 Alternate Discarding 1900 128 P2P po100 Alternate Discarding 1900 128 P2P
