| Skip Navigation Links | |
| Exit Print View | |
Sun Storage 6 Gb SAS REM HBA Installation Guide For HBA Models SGX-SAS6-REM-Z and SG-SAS6-REM-Z |
Chapter 2 Hardware Installation and Removal
Chapter 3 Creating a Bootable Drive in a Preboot Environment
Overview of Creating a Bootable Drive in a Preboot Environment
Methods For Creating a Bootable Drive
Creating a Bootable Drive (SPARC)
To Create a Bootable Drive (SPARC)
Using the FCode Utility to Create a Bootable Drive (SPARC)
To Prepare to Use the FCode Utility (SPARC)
To Create a RAID Volume With the FCode Utility (SPARC)
Creating a Bootable Drive (x86)
Using the UEFI Menu to Create a Bootable RAID Volume (x86)
To Verify the Drives and Their Slots (x86)
To Confirm the RAID Volume Creation (x86)
Using the BIOS Configuration Utility (Legacy BIOS Booting) to Create a Bootable Drive (x86)
To Prepare to Use the BIOS Configuration Utility
To Create a RAID Volume With the BIOS Configuration Utility (x86)
Selecting a Bootable Drive (x86)
To Select a Bootable Drive (x86)
Installing the Oracle Solaris OS
To Prepare to Install the Oracle Solaris OS
To Install the Oracle Solaris OS
This section describes how to create an alias for the bootable drive in order to help simplify the process of booting the drive. This section contains the following topic:
Note that, as shown in the following example, you can determine the HBA drives by looking for the LSI,sas@number label, where number is 0 for the first HBA detected, and increments for each additional HBA detected.
{0} ok show-disks
a) /pci@1e,600000/pci@0/pci@3/LSI,sas@0/disk
b) /pci@1e,600000/pci@0/pci@3/LSI,sas@1/disk
c) /pci@1e,600000/pci@0/pci@3/LSI,sas@2/disk
q) NO SELECTION
Enter Selection, q to quit:
a) /pci@1e,600000/pci@0/pci@3/LSI,sas@0/disk b) /pci@1e,600000/pci@0/pci@3/LSI,sas@1/disk c) /pci@1e,600000/pci@0/pci@3/LSI,sas@2/disk <...> q) NO SELECTION Enter Selection, q to quit: c /pci@1e,600000/pci@0/pci@3/LSI,sas@2/disk has been selected.
In the following example, the alias name is mydev.
{0} ok nvalias mydev /pci@1e,600000/pci@0/pci@3/LSI,sas@2/disk
{0} ok boot mydev
{0} ok printenv boot-device
boot-device = disk0 disk1
{0} ok setenv boot-device mydev disk0
boot-device = mydev disk0
In this example, the mydev alias is set as disk0, the first disk in the boot device list. This results in the automatic booting of the bootable drive, /pci@1e,600000/pci@0/pci@3/LSI,sas@2/disk.
