| Skip Navigation Links | |
| Exit Print View | |
Sun Storage 6 Gb SAS REM HBA Installation Guide For HBA Models SGX-SAS6-REM-Z and SG-SAS6-REM-Z |
Chapter 2 Hardware Installation and Removal
Chapter 3 Creating a Bootable Drive in a Preboot Environment
Overview of Creating a Bootable Drive in a Preboot Environment
Methods For Creating a Bootable Drive
Creating a Bootable Drive (SPARC)
To Create a Bootable Drive (SPARC)
Using the FCode Utility to Create a Bootable Drive (SPARC)
To Prepare to Use the FCode Utility (SPARC)
To Create a RAID Volume With the FCode Utility (SPARC)
Creating an Alias for a Bootable Drive (SPARC)
To Create an Alias for a Bootable Drive (SPARC)
Using the UEFI Menu to Create a Bootable RAID Volume (x86)
To Verify the Drives and Their Slots (x86)
To Confirm the RAID Volume Creation (x86)
Using the BIOS Configuration Utility (Legacy BIOS Booting) to Create a Bootable Drive (x86)
To Prepare to Use the BIOS Configuration Utility
To Create a RAID Volume With the BIOS Configuration Utility (x86)
Selecting a Bootable Drive (x86)
To Select a Bootable Drive (x86)
Installing the Oracle Solaris OS
To Prepare to Install the Oracle Solaris OS
To Install the Oracle Solaris OS
You have the following methods for creating a bootable drive on an x86 system:
If you have set your system BIOS to boot in UEFI BIOS mode (which you can specify through the Boot menu of the BIOS Setup utility), do one of the following:
- Install the OS on a non-RAID volume by using the Oracle System Assistant utility. For more information, see the Oracle System Assistant documentation.
- Install the OS on a RAID volume by setting up a RAID volume with the UEFI menu of the Setup utility, as described in Using the UEFI Menu to Create a Bootable RAID Volume (x86).
If you have set your system BIOS to boot in legacy mode (which you can specify through the Boot menu of the BIOS Setup utility), follow the steps in Using the BIOS Configuration Utility (Legacy BIOS Booting) to Create a Bootable Drive (x86).
