| Skip Navigation Links | |
| Exit Print View | |
man pages section 3: Library Interfaces and Headers Oracle Solaris 11 Express 11/10 |
SMHBA_GetAdapterAttributes(3LIB)
SMHBA_GetAdapterPortAttributes(3LIB)
SMHBA_GetBindingCapability(3LIB)
SMHBA_GetDiscoveredPortAttributes(3LIB)
SMHBA_GetFCPhyAttributes(3LIB)
SMHBA_GetPersistentBinding(3LIB)
SMHBA_GetPortAttributesByWWN(3LIB)
SMHBA_GetProtocolStatistics(3LIB)
SMHBA_GetSASPhyAttributes(3LIB)
SMHBA_GetVendorLibraryAttributes(3LIB)
SMHBA_GetWrapperLibraryAttributes(3LIB)
SMHBA_RegisterForAdapterAddEvents(3LIB)
SMHBA_RegisterForAdapterEvents(3LIB)
SMHBA_RegisterForAdapterPhyStatEvents(3LIB)
SMHBA_RegisterForAdapterPortEvents(3LIB)
SMHBA_RegisterForAdapterPortStatEvents(3LIB)
SMHBA_RegisterForTargetEvents(3LIB)
SMHBA_RemoveAllPersistentBindings(3LIB)
SMHBA_RemovePersistentBinding(3LIB)
- format of directory entries
#include <dirent.h>
The internal format of directories is unspecified. The <dirent.h> header defines the following type:
A type representing a directory stream.
The header also defines the structure dirent, which includes the following members:
ino_t d_ino /* file serial number */ char d_name[] /* name of entry */
The type ino_t is defined as described in <sys/types.h>. See types(3HEAD).
The character array d_name is of unspecified size, but the number of bytes preceding the terminating null byte must not exceed {NAME_MAX}.
closedir(3C), opendir(3C), readdir(3C), rewinddir(3C), seekdir(3C), telldir(3C), types.h(3HEAD), attributes(5), standards(5)
