| Skip Navigation Links | |
| Exit Print View | |
man pages section 3: Library Interfaces and Headers Oracle Solaris 11 Express 11/10 |
SMHBA_GetAdapterAttributes(3LIB)
SMHBA_GetAdapterPortAttributes(3LIB)
SMHBA_GetBindingCapability(3LIB)
SMHBA_GetDiscoveredPortAttributes(3LIB)
SMHBA_GetFCPhyAttributes(3LIB)
SMHBA_GetPersistentBinding(3LIB)
SMHBA_GetPortAttributesByWWN(3LIB)
SMHBA_GetProtocolStatistics(3LIB)
SMHBA_GetSASPhyAttributes(3LIB)
SMHBA_GetVendorLibraryAttributes(3LIB)
SMHBA_GetWrapperLibraryAttributes(3LIB)
SMHBA_RegisterForAdapterAddEvents(3LIB)
SMHBA_RegisterForAdapterEvents(3LIB)
SMHBA_RegisterForAdapterPhyStatEvents(3LIB)
SMHBA_RegisterForAdapterPortEvents(3LIB)
SMHBA_RegisterForAdapterPortStatEvents(3LIB)
SMHBA_RegisterForTargetEvents(3LIB)
SMHBA_RemoveAllPersistentBindings(3LIB)
SMHBA_RemovePersistentBinding(3LIB)
- user context
#include <ucontext.h>
The <ucontext.h> header defines the ucontext_t type as a structure that includes at least the following members:
ucontext_t uc_link sigset_t uc_sigmask stack_t uc_stack mcontext_t uc_mcontext
The uc_link member is a pointer to the context to be resumed when this context returns. If uc_link is equal to 0, this context is the main context and the process exits when this context returns.
The uc_sigmask member defines the set of signals that are blocked when this context is active. See sigprocmask(2).
The uc_stack member defines the stack used by this context. See sigaltstack(2).
The uc_mcontext member contains the saved set of machine registers and any implementation-specific context data. Portable applications should not modify or access uc_mcontext.
getcontext(2), sigaction(2), sigaltstack(2), sigprocmask(2), makecontext(3C), attributes(5), standards(5)
