| Skip Navigation Links | |
| Exit Print View | |
man pages section 3: Library Interfaces and Headers Oracle Solaris 11 Express 11/10 |
SMHBA_GetAdapterAttributes(3LIB)
SMHBA_GetAdapterPortAttributes(3LIB)
SMHBA_GetBindingCapability(3LIB)
SMHBA_GetDiscoveredPortAttributes(3LIB)
SMHBA_GetFCPhyAttributes(3LIB)
SMHBA_GetPersistentBinding(3LIB)
SMHBA_GetPortAttributesByWWN(3LIB)
SMHBA_GetProtocolStatistics(3LIB)
SMHBA_GetSASPhyAttributes(3LIB)
SMHBA_GetVendorLibraryAttributes(3LIB)
SMHBA_GetWrapperLibraryAttributes(3LIB)
SMHBA_RegisterForAdapterAddEvents(3LIB)
SMHBA_RegisterForAdapterEvents(3LIB)
SMHBA_RegisterForAdapterPhyStatEvents(3LIB)
SMHBA_RegisterForAdapterPortEvents(3LIB)
SMHBA_RegisterForAdapterPortStatEvents(3LIB)
SMHBA_RegisterForTargetEvents(3LIB)
SMHBA_RemoveAllPersistentBindings(3LIB)
SMHBA_RemovePersistentBinding(3LIB)
- VFS File System information structure
#include <sys/statvfs.h>
The <sys/statvfs.h> header defines the statvfs structure, which includes the following members:
unsigned long f_bsize /* file system block
size */
unsigned long f_frsize /* fundamental file system block
size */
fsblkcnt_t f_blocks /* total number of blocks on file
system in units of f_frsize */
fsblkcnt_t f_bfree /* total number of free blocks */
fsblkcnt_t f_bavail /* number of free blocks available
to non-privileged process */
fsfilcnt_t f_files /* total number of file serial
numbers */
fsfilcnt_t f_ffree /* total number of free file serial
numbers */
fsfilcnt_t f_favail /* number of file serial numbers
available to non-privileged
unsigned long f_fsid /* process file system ID */
unsigned long f_flag /* bit mask of f_flag values */
unsigned long f_namemax /* maximum filename length */The fsblkcnt_t and fsfilcnt_t types are defined as described in <sys/types.h>. See types.h(3HEAD).
The following flags for the f_flag member are defined:
read-only file system
does not support setuid()/setgid() semantics
