| Skip Navigation Links | |
| Exit Print View | |
man pages section 3: Library Interfaces and Headers Oracle Solaris 11 Express 11/10 |
SMHBA_GetAdapterAttributes(3LIB)
SMHBA_GetAdapterPortAttributes(3LIB)
SMHBA_GetBindingCapability(3LIB)
SMHBA_GetDiscoveredPortAttributes(3LIB)
SMHBA_GetFCPhyAttributes(3LIB)
SMHBA_GetPersistentBinding(3LIB)
SMHBA_GetPortAttributesByWWN(3LIB)
SMHBA_GetProtocolStatistics(3LIB)
SMHBA_GetSASPhyAttributes(3LIB)
SMHBA_GetVendorLibraryAttributes(3LIB)
SMHBA_GetWrapperLibraryAttributes(3LIB)
SMHBA_RegisterForAdapterAddEvents(3LIB)
SMHBA_RegisterForAdapterEvents(3LIB)
SMHBA_RegisterForAdapterPhyStatEvents(3LIB)
SMHBA_RegisterForAdapterPortEvents(3LIB)
SMHBA_RegisterForAdapterPortStatEvents(3LIB)
SMHBA_RegisterForTargetEvents(3LIB)
SMHBA_RemoveAllPersistentBindings(3LIB)
SMHBA_RemovePersistentBinding(3LIB)
- standard library definitions
#include <stdlib.h>
The <stdlib.h> header defines the following macros:
Unsuccessful termination for exit(); evaluates to a non-zero value. See exit(3C).
Successful termination for exit(); evaluates to 0.
Null pointer.
Maximum value returned by rand(); at least 32767. See rand(3C).
Integer expression whose value is the maximum number of bytes in a character specified by the current locale.
The following data types are defined through typedef:
structure type returned by the div() function
structure type returned by the ldiv() function
structure type returned by the lldiv() function
as described in <stddef.h>
See div(3C), which covers div(), ldiv(), and lldiv(), and stddef.h(3HEAD).
In addition, the symbolic names and macros listed below are defined as in <sys/wait.h>, for use in decoding the return value from system(). See wait.h(3HEAD) and system(3C).
WNOHANG WUNTRACED WEXITSTATUS WIFEXITED WIFSIGNALED WIFSTOPPED WSTOPSIG WTERMSIG
a64l(3C), abort(3C), abs(3C), atexit(3C), bsearch(3C), div(3C), drand48(3C), exit(3C), getenv(3C), getsubopt(3C), grantpt(3C), malloc(3C), mblen(3C), mbstowcs(3C), mbtowc(3C), mkstemp(3C), ptsname(3C), putenv(3C), qsort(3C), random(3C), realpath(3C), strtod(3C), strtol(3C), strtoul(3C), unlockpt(3C), wcstombs(3C), wctomb(3C), limits.h(3HEAD), math.h(3HEAD), stddef.h(3HEAD), types.h(3HEAD), wait.h(3HEAD), attributes(5), standards(5)
