| Skip Navigation Links | |
| Exit Print View | |
Sun Server X2-4 (formerly Sun Fire X4470 M2) Installation Guide for Windows Operating System |
Part I Windows Server Installations
1. Assisted OS Installation With Oracle Hardware Installation Assistant
Oracle Hardware Installation Assistant Task Overview
How to Obtain Oracle Hardware Installation Assistant
Oracle Hardware Installation Assistant Documentation Resources
Supported Windows Server Operating Systems
Windows Installation Prerequisites
Windows Server Installation Task Overview
SAS PCIe HBAs Requiring LSI Mass Storage Driver for Windows Server 2008 SP2
3. Installing Windows Server 2008
Installing Windows Server Using Local or Remote Media
Windows Server Installation Using a PXE Network Boot
4. Post Installation of Windows Server 2008
Installing Critical Device Drivers and Supplemental Software
Installing Supplemental Software
5. Getting Server Firmware and Software
Firmware and Software Access Options
Available Software Release Packages
Accessing Firmware and Software
Part II Windows Server System Administrator References
A. Supported Installation Methods
B. Supported Operating Systems
C. BIOS Defaults for New Installations
Verification of BIOS Factory Defaults
D. Incorporating Device Drivers Into Windows Server 2008 WIM Images for Windows Deployment Services
Location of Device Drivers on Tools and Drivers Firmware DVD
Which Device Drivers to Incorporate Into WIM Image(s)
Prerequisites and Task Overview
Procedures for Incorporating Drivers Into WIM Image(s)
Create an ImageUnattend.xml Setup Script – Windows Server 2008 (SP2 or R2)
Map ImageUnattend.xml Setup Script to Windows Server 2008 (SP2 or R2) Install Image
Note - If you are performing a Windows Server 2008 R2 installation, skip this procedure. Device drivers are not required at boot time for Windows Server 2008 R2 installations.
For Windows Server 2008 SP2 installations only, perform the following steps to add the appropriate PCIe SAS HBA LSI device driver (MegaRAID or MPT2) to the boot.wim image. Note that if the required PCIe SAS HBA device driver (as described in Device Driver Directory Location on Tools and Drivers Firmware DVD and Device Drivers to Add to WIM Image(s)) is not added to the boot.wim image, the Windows Server 2008 SP2 installation will fail.
For example: DVDDrive:\sources\boot.wim
For example:
For example:
mkdir C:\Mnt
For example:
cd DVDDrive:\RemoteInstall\Boot\x64\images
For example:
imagex /mountrw boot.wim 2 C:\Mnt
For example, to change to the directory containing the LSI device driver for the Sun Storage 6 Gb SAS PCIe RAID HBA option (SG-SAS-R-INT-Z), type:
cd C:\Unattend\Drivers\W2K8\lsi\1.19.2.64
For example, to add the LSI MegaRAID device driver for the Sun Storage 6 Gb SAS PCIe RAID HBA option (SG-SAS-R-INT-Z), type:
peimg /INF=*.inf C:\Mnt\Windows
For example:
imagex /unmount/commit C:\Mnt
