| Skip Navigation Links | |
| Exit Print View | |
Oracle Enterprise Manager Ops Center on SuperCluster Systems Supplement |
Oracle Enterprise Manager Ops Center for SuperCluster Systems
Accessing Oracle Enterprise Manager Ops Center Documentation
Restrictions on SuperCluster Systems
Discovering a SuperCluster Component
Add an Asset to the SuperCluster Rack
Viewing and Managing the System
Oracle Enterprise Manager Ops Center is initially installed on the SuperCluster system by Oracle ACS. This section describes the rules followed to install Oracle Enterprise Manager Ops Center on SuperCluster.
Oracle Enterprise Manager Ops Center should be installed on the compute node in an Oracle Solaris 11 Control Domain. If the SuperCluster system comes with an Oracle 11gR2 Database, it will be installed in this domain. The Control Domain on another compute node will be used for a standby Enterprise Controller should HA be configured later.
Enterprise Controllers intended to manage SuperCluster cannot be installed outside of SuperCluster.
Oracle Enterprise Manager Ops Center cannot be installed in a zone on SuperCluster.
Oracle Enterprise Manager Ops Center will be installed with co-located Proxy Controllers, which means the Proxy Controllers will be placed on the same nodes as the Enterprise Controllers, but will be configured in HA mode.
Note - In case of the current non-HA default installation there will be just one proxy controller collocated with a single Enterprise Controller.
Oracle Enterprise Manager Ops Center should use the Oracle 11gR2 Database connected to the storage servers on SuperCluster.
All SuperCluster assets are discovered during the installation process and should appear in the Oracle Enterprise Manager Ops Center user interface SuperCluster View mode.
