Skip Navigation Links
Exit Print View
Oracle Enterprise Manager Ops Center on SuperCluster Systems
Supplement
search filter icon
search icon
Document Information
Using This Documentation
Related Documentation
Feedback
Access to Oracle Support
Oracle Enterprise Manager Ops Center for SuperCluster Systems
Overview
Accessing Oracle Enterprise Manager Ops Center Documentation
Installation Rules
Restrictions on SuperCluster Systems
Understanding User Roles
Discovering a SuperCluster Component
Add a Component Manually
Add an Asset to the SuperCluster Rack
Viewing and Managing the System
View and Manage the Rack
View and Manage Components
Using Monitoring Profiles and Rules
Creating a Monitoring Profile
Adding a Monitoring Rule
Creating and Viewing Reports
Creating a Report
View a Report
Incident Management
Overview
Oracle Enterprise Manager Ops Center is Oracle's comprehensive system management solution for monitoring and managing the physical and virtual operating systems, servers, and storage devices in your data center.
Oracle Enterprise Manager Ops Center manages SuperCluster differently from a traditional data center asset. A SuperCluster system is managed as its own, self-contained data center, with Oracle Enterprise Manager Ops Center installed and run internally on SuperCluster. The entire SuperCluster system can be passively monitored as one asset by the data center Oracle Enterprise Manager Ops Center, but any active management of the SuperCluster components must occur from the internal Oracle Enterprise Manager Ops Center instance on SuperCluster.
The following sections describe using Oracle Enterprise Manager Ops Center on SuperCluster systems. These sections assume you are logging in to the instance of Oracle Enterprise Manager Ops Center that is installed on the SuperCluster system.
