| Skip Navigation Links | |
| Exit Print View | |
Oracle Enterprise Manager Ops Center on SuperCluster Systems Supplement |
Oracle Enterprise Manager Ops Center for SuperCluster Systems
Accessing Oracle Enterprise Manager Ops Center Documentation
Restrictions on SuperCluster Systems
Discovering a SuperCluster Component
Add an Asset to the SuperCluster Rack
Viewing and Managing the System
Before You Begin
You will need the following to create a SuperCluster Report and view it:
A system running Oracle Enterprise Manager Ops Center.
Access to Oracle Enterprise Manager Ops Center with a SuperCluster System Admin role.
A SuperCluster system deployed and discovered in Oracle Enterprise Manager Ops Center.
The Report Templates and Report Results are displayed in the center pane.
The Create SuperCluster System Report wizard opens.
The Schedule and Output Format are checked by default.
Select Create Schedule if you want to run the report later or on a recurring schedule.
Select the output formats of the result that will be generated for the report.
You can schedule the report to run on the following instances:
Now - Runs the report immediately.
At a later date/time - Select a date and time to generate the report.
On a Recurring Schedule - Select the month and day when you want to generate the report. Select the Start Time, End Time and Number of Hours between runs. This is to set the number of times the report is generated between the specified start and end time. For example, if you set the start time at 6.00 a.m, end time at 12.00 a.m, and the number of hours between runs as 2, then the report is run at 6.00 a.m, 8.00 a.m, 10.00 a.m, and 12.00 a.m.
Save Template and Close - Saves the report as a template and closes the wizard. You can use the report template to generate the report later.
Run and Close - Runs the report and closes the wizard window.
Once you have triggered the report creation process, the job starts to run. You can view the status of your report in the Report Results section. Upon successful completion, a green check mark is displayed in the status column and the report is ready to be viewed
