Skip Navigation Links
Exit Print View
Oracle Enterprise Manager Ops Center on SuperCluster Systems
Supplement
search filter icon
search icon
Document Information
Using This Documentation
Related Documentation
Feedback
Access to Oracle Support
Oracle Enterprise Manager Ops Center for SuperCluster Systems
Overview
Accessing Oracle Enterprise Manager Ops Center Documentation
Installation Rules
Restrictions on SuperCluster Systems
Understanding User Roles
Discovering a SuperCluster Component
Add a Component Manually
Add an Asset to the SuperCluster Rack
Viewing and Managing the System
View and Manage the Rack
View and Manage Components
Using Monitoring Profiles and Rules
Creating a Monitoring Profile
Adding a Monitoring Rule
Creating and Viewing Reports
Creating a Report
View a Report
Incident Management
Use this procedure to add a monitoring rule from the Asset view.
  1. Click Assets in the Navigation pane, expand the tree and click the asset to which you want to add the rule.
  2. Click the Monitoring tab to see a list of all the monitoring rules.
  3. Click the Add Alert Monitoring Rule icon in the center pane. The Add Alert Monitoring Rule Parameters window is displayed.
  4. Select a Rule Type from the drop-down menu: Threshold, Boolean Control, Enumerated Control or Expression.
  5. Select an Asset Type from the drop-down menu.
  6. Complete the Monitored Attribute. If you selected Expression, the Monitored Attribute option is not available.
  7. Provide a name and description for the rule that will appear in the Profile Details page.
  8. Define the monitoring schedule, either continuously or for a specific time period.
    The start and end times are based on the monitored asset's time zone.
  9. Define how long the alerting condition must last to be considered an alert.
    The default setting is 5 minutes. You can change the amount of time and the unit of measurement to be either minutes, hours, or days.
  10. Complete the Alert parameters for the different severity levels.
  11. Use the Immediate Action field to define what action should take place when a problem is detected.
  12. Click Apply to save the rule. The new rule will appear in the profile.
