| Skip Navigation Links | |
| Exit Print View | |
Oracle Enterprise Manager Ops Center on SuperCluster Systems Supplement |
Oracle Enterprise Manager Ops Center for SuperCluster Systems
Accessing Oracle Enterprise Manager Ops Center Documentation
Restrictions on SuperCluster Systems
Add an Asset to the SuperCluster Rack
Viewing and Managing the System
If a component is changed or installed after the initial system installation, you might need to manually discovery that component. The component can either be a compute node, storage, or switch. To add a component to SuperCluster, you must first discover the component, then add it to the SuperCluster rack. Use the following procedures to complete these tasks.
