| Skip Navigation Links | |
| Exit Print View | |
Oracle Fusion Middleware Administration Guide for Oracle Unified Directory 11g Release 1 (11.1.1) |
1. Starting and Stopping the Server
2. Configuring the Server Instance
3. Configuring the Proxy Components
4. Configuring Security Between Clients and Servers
5. Configuring Security Between the Proxy and the Data Source
6. Managing Oracle Unified Directory With Oracle Directory Services Manager
10. Managing Users and Groups With dsconfig
11. Managing Password Policies
13. Monitoring Oracle Unified Directory
Tuning Java Virtual Machine Settings
You can obtain a quick idea of whether performance issues are related to problems with the server or with the client by examining the access log at install-dir/logs/access. This log contains entries of the form:
[09/Sep/2009:15:36:18 +0200] SEARCH RES conn=1 op=16 msgID=17 result=0 nentries=1 etime=1
The value of the etime field is the time (in milliseconds) that the server spent processing the request. Large etimes generally indicate an issue on the server side (which can usually be resolved by appropriate performance tuning or indexing. If you are experiencing performance problems but the etimes are small, the issue is more likely to be with your client application.
