Skip Navigation Links | |
Exit Print View | |
man pages section 3: Library Interfaces and Headers Oracle Solaris 11 Information Library |
SMHBA_GetAdapterAttributes(3LIB)
SMHBA_GetAdapterPortAttributes(3LIB)
SMHBA_GetBindingCapability(3LIB)
SMHBA_GetDiscoveredPortAttributes(3LIB)
SMHBA_GetFCPhyAttributes(3LIB)
SMHBA_GetPersistentBinding(3LIB)
SMHBA_GetPortAttributesByWWN(3LIB)
SMHBA_GetProtocolStatistics(3LIB)
SMHBA_GetSASPhyAttributes(3LIB)
SMHBA_GetVendorLibraryAttributes(3LIB)
SMHBA_GetWrapperLibraryAttributes(3LIB)
SMHBA_RegisterForAdapterAddEvents(3LIB)
SMHBA_RegisterForAdapterEvents(3LIB)
SMHBA_RegisterForAdapterPhyStatEvents(3LIB)
SMHBA_RegisterForAdapterPortEvents(3LIB)
SMHBA_RegisterForAdapterPortStatEvents(3LIB)
SMHBA_RegisterForTargetEvents(3LIB)
SMHBA_RemoveAllPersistentBindings(3LIB)
SMHBA_RemovePersistentBinding(3LIB)
- codeset conversion facility
#include <iconv.h>
The <iconv.h> header defines the following type:
Identifies the conversion from one codeset to another.
The following symbolic constants are defined as possible values for an operation request in query or setting of the iconv code conversion behavior of the current conversion:
The following symbolic constants are defined, zero or more of which can be bitwise-inclusively OR'ed together to form the conversion behavior settings for some of the above operation requests:
For more information on the above symbolic constants, see iconv(3C), iconvctl(C), iconv_open(3C), and iconvstr(3C).
iconv(3C), iconv_close(3C), iconv_open(3C), iconvctl(C), iconvstr(3C), attributes(5), standards(5)
