Skip Navigation Links | |
Exit Print View | |
man pages section 3: Library Interfaces and Headers Oracle Solaris 11 Information Library |
SMHBA_GetAdapterAttributes(3LIB)
SMHBA_GetAdapterPortAttributes(3LIB)
SMHBA_GetBindingCapability(3LIB)
SMHBA_GetDiscoveredPortAttributes(3LIB)
SMHBA_GetFCPhyAttributes(3LIB)
SMHBA_GetPersistentBinding(3LIB)
SMHBA_GetPortAttributesByWWN(3LIB)
SMHBA_GetProtocolStatistics(3LIB)
SMHBA_GetSASPhyAttributes(3LIB)
SMHBA_GetVendorLibraryAttributes(3LIB)
SMHBA_GetWrapperLibraryAttributes(3LIB)
SMHBA_RegisterForAdapterAddEvents(3LIB)
SMHBA_RegisterForAdapterEvents(3LIB)
SMHBA_RegisterForAdapterPhyStatEvents(3LIB)
SMHBA_RegisterForAdapterPortEvents(3LIB)
SMHBA_RegisterForAdapterPortStatEvents(3LIB)
SMHBA_RegisterForTargetEvents(3LIB)
SMHBA_RemoveAllPersistentBindings(3LIB)
SMHBA_RemovePersistentBinding(3LIB)
- definitions for vector I/O operations
#include <sys/uio.h>
The <sys/uio.h> header defines the iovec structure, which includes the following members:
void *iov_base /* base address of a memory region for input or output */ size_t iov_len /* size of the memory pointed to by iov_base */
The <sys/uio.h> header uses the iovec structure for scatter/gather I/O.
The ssize_t and size_t types are defined as described in <sys/types.h>.
The symbol {IOV_MAX} defined in <limits.h> should always be used to learn about the limits on the number of scatter/gather elements that can be processed in one call, instead of assuming a fixed value.
read(2), write(2), limits.h(3HEAD), types.h(3HEAD), attributes(5), standards(5)
