Skip Navigation Links | |
Exit Print View | |
man pages section 3: Library Interfaces and Headers Oracle Solaris 11 Information Library |
SMHBA_GetAdapterAttributes(3LIB)
SMHBA_GetAdapterPortAttributes(3LIB)
SMHBA_GetBindingCapability(3LIB)
SMHBA_GetDiscoveredPortAttributes(3LIB)
SMHBA_GetFCPhyAttributes(3LIB)
SMHBA_GetPersistentBinding(3LIB)
SMHBA_GetPortAttributesByWWN(3LIB)
SMHBA_GetProtocolStatistics(3LIB)
SMHBA_GetSASPhyAttributes(3LIB)
SMHBA_GetVendorLibraryAttributes(3LIB)
SMHBA_GetWrapperLibraryAttributes(3LIB)
SMHBA_RegisterForAdapterAddEvents(3LIB)
SMHBA_RegisterForAdapterEvents(3LIB)
SMHBA_RegisterForAdapterPhyStatEvents(3LIB)
SMHBA_RegisterForAdapterPortEvents(3LIB)
SMHBA_RegisterForAdapterPortStatEvents(3LIB)
SMHBA_RegisterForTargetEvents(3LIB)
SMHBA_RemoveAllPersistentBindings(3LIB)
SMHBA_RemovePersistentBinding(3LIB)
- word-expansion types
#include <wordexp.h>
The <wordexp.h> header defines the structures and symbolic constants used by the wordexp() and wordfree() functions. See wordexp(3C).
The structure type wordexp_t contains the following members:
size_t we_wordc /* count of words matched by words */ char **we_wordv /* pointer to list of expanded words */ size_t we_offs /* slots to reserve at the beginning of we_wordv */
The flags argument to the wordexp() function is the bitwise-inclusive OR of the following flags:
Append words to those previously generated.
Number of null pointers to prepend to we_wordv.
Fail if command substitution is requested.
The pwordexp argument was passed to a previous successful call to wordexp(), and has not been passed to wordfree(). The result is the same as if the application had called wordfree() and then called wordexp() without WRDE_REUSE.
Do not redirect stderr to /dev/null.
Report error on an attempt to expand an undefined shell variable.
The following constants are defined as error return values:
One of the unquoted characters—<newline>, '|', '&', ';', '<', '>', '(', ')', '{', '}'—appears in words in an inappropriate context.
Reference to undefined shell variable when WRDE_UNDEF is set in flags.
Command substitution requested when WRDE_NOCMD was set in flags.
Attempt to allocate memory failed.
Reserved.
Shell syntax error, such as unbalanced parentheses or unterminated string.
The <wordexp.h> header defines the following type:
As described in <stddef.h>.
