Skip Navigation Links | |
Exit Print View | |
man pages section 3: Library Interfaces and Headers Oracle Solaris 11 Information Library |
SMHBA_GetAdapterAttributes(3LIB)
SMHBA_GetAdapterPortAttributes(3LIB)
SMHBA_GetBindingCapability(3LIB)
SMHBA_GetDiscoveredPortAttributes(3LIB)
SMHBA_GetFCPhyAttributes(3LIB)
SMHBA_GetPersistentBinding(3LIB)
SMHBA_GetPortAttributesByWWN(3LIB)
SMHBA_GetProtocolStatistics(3LIB)
SMHBA_GetSASPhyAttributes(3LIB)
SMHBA_GetVendorLibraryAttributes(3LIB)
SMHBA_GetWrapperLibraryAttributes(3LIB)
SMHBA_RegisterForAdapterAddEvents(3LIB)
SMHBA_RegisterForAdapterEvents(3LIB)
SMHBA_RegisterForAdapterPhyStatEvents(3LIB)
SMHBA_RegisterForAdapterPortEvents(3LIB)
SMHBA_RegisterForAdapterPortStatEvents(3LIB)
SMHBA_RegisterForTargetEvents(3LIB)
SMHBA_RemoveAllPersistentBindings(3LIB)
SMHBA_RemovePersistentBinding(3LIB)
- spawn
#include <spawn.h>
The <spawn.h> header defines the posix_spawnattr_t and posix_spawn_file_actions_t types used in performing spawn operations.
The <spawn.h> header defines the flags that can be set in a posix_spawnattr_t object using the posix_spawnattr_setflags() function:
POSIX_SPAWN_RESETIDS POSIX_SPAWN_SETPGROUP POSIX_SPAWN_SETSCHEDPARAM POSIX_SPAWN_SETSCHEDULER POSIX_SPAWN_SETSIGDEF POSIX_SPAWN_SETSIGMASK
Inclusion of the <spawn.h> header can make visible symbols defined in the <sched.h>, <signal.h>, and <sys/types.h> headers.
sched.h(3HEAD), semaphore.h(3HEAD), signal.h(3HEAD), types.h(3HEAD), attributes(5), standards(5)
