Skip Navigation Links | |
Exit Print View | |
man pages section 3: Library Interfaces and Headers Oracle Solaris 11 Information Library |
SMHBA_GetAdapterAttributes(3LIB)
SMHBA_GetAdapterPortAttributes(3LIB)
SMHBA_GetBindingCapability(3LIB)
SMHBA_GetDiscoveredPortAttributes(3LIB)
SMHBA_GetFCPhyAttributes(3LIB)
SMHBA_GetPersistentBinding(3LIB)
SMHBA_GetPortAttributesByWWN(3LIB)
SMHBA_GetProtocolStatistics(3LIB)
SMHBA_GetSASPhyAttributes(3LIB)
SMHBA_GetVendorLibraryAttributes(3LIB)
SMHBA_GetWrapperLibraryAttributes(3LIB)
SMHBA_RegisterForAdapterAddEvents(3LIB)
SMHBA_RegisterForAdapterEvents(3LIB)
SMHBA_RegisterForAdapterPhyStatEvents(3LIB)
SMHBA_RegisterForAdapterPortEvents(3LIB)
SMHBA_RegisterForAdapterPortStatEvents(3LIB)
SMHBA_RegisterForTargetEvents(3LIB)
SMHBA_RemoveAllPersistentBindings(3LIB)
SMHBA_RemovePersistentBinding(3LIB)
- threads
#include <pthread.h>
The <pthread.h> header defines the following symbols:
PTHREAD_BARRIER_SERIAL_THREAD PTHREAD_CANCEL_ASYNCHRONOUS PTHREAD_CANCEL_ENABLE PTHREAD_CANCEL_DEFERRED PTHREAD_CANCEL_DISABLE PTHREAD_CANCELED PTHREAD_COND_INITIALIZER PTHREAD_CREATE_DETACHED PTHREAD_CREATE_JOINABLE PTHREAD_EXPLICIT_SCHED PTHREAD_INHERIT_SCHED PTHREAD_MUTEX_DEFAULT PTHREAD_MUTEX_ERRORCHECK PTHREAD_MUTEX_INITIALIZER PTHREAD_MUTEX_NORMAL PTHREAD_MUTEX_RECURSIVE PTHREAD_MUTEX_ROBUST PTHREAD_MUTEX_STALLED PTHREAD_ONCE_INIT PTHREAD_PRIO_INHERIT PTHREAD_PRIO_NONE PTHREAD_PRIO_PROTECT PTHREAD_PROCESS_SHARED PTHREAD_PROCESS_PRIVATE PTHREAD_RWLOCK_INITIALIZER PTHREAD_SCOPE_PROCESS PTHREAD_SCOPE_SYSTEM
The types listed below are defined as described in <sys/types.h>. See types.h(3HEAD).
pthread_attr_t pthread_barrier_t pthread_barrierattr_t pthread_cond_t pthread_condattr_t pthread_key_t pthread_mutex_t pthread_mutexattr_t pthread_once_t pthread_rwlock_t pthread_rwlockattr_t pthread_spinlock_t pthread_t
sched.h(3HEAD), time.h(3HEAD), types.h(3HEAD), pthread_attr_getguardsize(3C), pthread_attr_init(3C), pthread_attr_setscope(3C), pthread_cancel(3C), pthread_cleanup_pop(3C), pthread_cond_init(3C), pthread_cond_signal(3C), pthread_cond_wait(3C), pthread_condattr_init(3C), pthread_create(3C), pthread_detach(3C), pthread_equal(3C), pthread_exit(3C), pthread_getconcurrency(3C), pthread_getschedparam(3C), pthread_join(3C), pthread_key_create(3C), pthread_key_delete(3C), pthread_mutex_consistent(3C), pthread_mutex_init(3C), pthread_mutex_lock(3C), pthread_mutex_setprioceiling(3C), pthread_mutexattr_getrobust(3C), pthread_mutexattr_gettype(3C), pthread_mutexattr_getprotocol(3C), pthread_mutexattr_init(3C), pthread_once(3C), pthread_rwlock_init(3C), pthread_rwlock_rdlock(3C), pthread_rwlock_unlock(3C), pthread_rwlock_wrlock(3C), pthread_rwlockattr_getpshared(3C), pthread_rwlockattr_init(3C), pthread_self(3C), pthread_setcancelstate(3C), pthread_setspecific(3C), attributes(5), standards(5)
