Understanding the System Architecture
Understanding PCIe Device Root Complexes
Control Domain and Reserved Root Complexes
Fully-Populated Default Configuration
Understanding PCIe Slot Root Complex Names and Device Paths
PCIe Device Root Complex Failover Behavior
Understanding EMS SAS Paths to the Internal Drives
SAS Paths From EMS Module to Drives
Understanding Internal Drive Device Paths
HDD and SSD Device Path Differences
Understanding DCU0 Drive Device Paths
Understanding DCU1 Drive Device Paths
Understanding DCU2 Drive Device Paths
Understanding DCU3 Drive Device Paths
Understanding Network Port Device Paths
DCU0 Network Port Device Paths
DCU1 Network Port Device Paths
DCU2 Network Port Device Paths
DCU3 Network Port Device Paths
Understanding Configuration Guidelines
Understanding System Administration Resources
Understanding Platform-Specific Oracle ILOM Features
SPARC: Server-Specific and New Oracle ILOM Features and Requirements
Unsupported Oracle OS Features
Unsupported Oracle ILOM Features
Oracle VM Server for SPARC Overview
Multipathing Software Overview
Oracle ILOM Remote System Console Plus Overview
Oracle Hardware Management Pack Overview
Oracle Enterprise Manager Ops Center
Time Synchronization and NTP Service
Multi-Domain Extensions to ILOM MIBs
Establish a Network Management Connection to Oracle ILOM
Log In to Oracle ILOM (Web Interface)
Logging In to Oracle ILOM (CLI)
Switch Between the Oracle ILOM CLI and the System Console on a Host
Connect to a PDomain When the System Is Unconfigured and Powered Off
Connect to a PDomain When the Oracle Solaris OS Is Running
Connect to a PDomain When the Oracle Solaris OS Is Unresponsive
Get to the ok Prompt When the Host Is Powered On (Web Interface)
Connect to an LDoms Guest Domain
Connect to Oracle ILOM Remote System Console Plus
Enable Video Redirection From the Oracle Solaris OS
Configure Multiple Display Devices
Reestablish KVMS Connection to SPPs After a Reboot
Controlling the Server, Domains, and Devices
Resetting the Server, SP, or Domains
Reset the Server (Oracle Solaris)
Resetting the SP Configuration
Managing the Server's Boot Behavior
Change the Default Boot Device (ok Prompt)
Create an OpenBoot Boot Path to a Boot Disk
Enable or Disable Automatic Booting (ok Prompt)
SPARC: OpenBoot Boot Configuration Parameters
Booting and Shutting Down the OS
Manually Boot the OS (ok Prompt)
Configuring Oracle ILOM User Accounts and Roles
Understanding Platform and Host-Specific User Role Assignments
Configuring User Accounts (SNMP)
Configuring Host Groups to Authenticate User Accounts (CLI)
Configuring Host Groups to Authenticate User Accounts (SNMP)
Record Network Parameter Values
Viewing the Network Configuration
View Configuration Details for the Network
View Configuration Details for SPs and Hosts
Determine Which SP Is the Active SP
Change the Current Role of the SP Pair
Disable or Re-Enable Network Access to an SP or Host
Determine Current DCU Assignment
Migrate DCUs to a New PDomain (CLI)
Administering CMUs, CMPs, and DIMMs
Display Summary of Installed CMUs
Administering IOUs and PCIe Device Root Complexes
Manage I/O Path Reconfiguration Settings
Identify the Root Complex of a Device
Identifying Domain-Level Commands
PDomain Configuration and Monitoring Commands
Single Sign-On Service Network Deployment Commands
Dedicated SP Interconnect Property Commands
FMA Fault Proxying and Reserved Root Complexes
Virtual Keyswitch Property Commands
Locate the Server (Web Interface)
Obtain the Server Serial Number
Viewing Server and Component Information
Viewing System-Level Information
Viewing Individual Component Properties
XSCF and Oracle ILOM Command Comparison
Identifying SP Configuration and Administration Commands
User Account Administration Commands
Network Configuration/Administration Commands
A server power cord AC receptacle.
Memory buffer on board. An ASIC on a CMU board that transfers data between a DIMM and a CMP.
A type of PDomain which is limited to one DCU. A Bounded PDomain will typically exhibit higher performance as all resources are local to the single DCU. Bounded PDomains are not subject to SSB failure. Bounded PDomains can contain up to eight CMPs.
Label of the PCIe hot-plug carrier.
Cubic feet per minute.
Label for a clock board. The sever contains two dual-redundant clock boards.
Chip multiprocessing. Each CMU contains two CMP processors. The server can contain a maximum of 32 CMPs.
CPU memory unit. Each CMU contains two CMPs and two sets of DIMM slots.
Domain configuration management. DCM refers to the reconfiguration of boards in physical domains for Enterprise-class systems.
Domain configurable unit. Each DCU contains two or four CMUs and one IOU. The smallest building block for physical domains.
Dynamic Host Configuration Protocol. Software that automatically assigns IP addresses to clients on a Transmission Control Protocol/Internet Protocol (TCP/IP) network.
Dual in-line memory module.
Electromagnetic interference.
Express module SAS. Each EMS contains two 10GBASE-T network connections and provides access to four hard drives on the server.
Electrostatic discharge.
Fault management architecture. Generates fault indictments from the SP. FMA provides three system activities: error handling, fault diagnosis, and response.
Field-replaceable unit.
Gigabyte. 1 gigabyte = 1024 megabytes.
Gigabit Ethernet.
Hard disk drive. In Oracle Solaris OS output, HDD can refer to hard disk drives or solid state drives (SSDs).
See Oracle ILOM.
I/O unit. The server contains up to four IOUs, one for each DCU. Each IOU supports up to 16 PCIe slots, 8 10GBASE-T ports on 4 EMS modules, and 8 hard drives.
Keyboard video mouse storage.
Kilowatt.
A virtual machine comprising a discrete logical grouping of resources that has its own operating system and identity within a single computer system.
Line-to-line. Line-to-line voltage is the voltage between any two phases of an AC generator.
The network management port on a SP.
OpenBoot PROM. Firmware that is installed on the server and provides an interface through which you can perform various diagnostic tasks.
Oracle Integrated Lights-Out Manager (Oracle ILOM) firmware.
Oracle Solaris operating system.
Oracle Validation Test Suite. An application that exercises the system, provides hardware validation, and identifies possible faulty components.
Peripheral Component Interconnect Express.
An enclosure used to install and house PCIe cards in the server.
Physical domain. Each PDomain is an independently configurable and bootable entity with full hardware domain isolation for fault isolation and security purposes.The maximum number of PDomains supported is four, which is equal to the number of DCUs. The minimum number of PDomains is one, which can be composed of all available DCUs within the system.
DCUs in a PDomain communicate with other DCUs in the server through the SSBs. If an SSB fails, the PDomain availability will be impacted. Bounded PDomains are limited to one DCU and are not affected by SSB failures.
See also Bounded PDomain, DCU, and SSB.
The lead SPP of a physical domain. The PDomain-SPP manages tasks and provides rKVMS service for that physical domain.
Power-on self test. A diagnostic that runs when the server boots.
Power system distribution board.
Predictive self healing. An Oracle Solaris OS technology that continuously monitors the health of the server and works with Oracle ILOM to take a faulty component offline if needed.
Remote keyboard video mouse and storage.
Root mean square.
Serial attached SCSI.
Serial advance technology attachment.
Scalability is the ability to increase (or scale up) processing power in a server by combining the server's physical configurable hardware (see DCU) into one or more logical groups (see PDomain).
The serial management port on a SP.
Service processor. For redundancy, the server contains two service processors, one being active and one on standby.
Service processor proxy. One SPP is assigned to manage each PDomain. SPPs monitor environmental sensors and manage the CMUs, memory controllers, and DIMMs within the DCU.
See PDomain-SPP.
Scalability switch board.
Solid state drive.
Secure shell. A program for logging in and executing commands on a system or service processor.
Terabyte. 1 terabyte = 1024 gigabytes.
A type of screw head characterized by a 6-point star-shaped pattern.
Uninterruptible power supply.
Voltage alternating current.
Virtual local area network.
See Oracle VTS.
World wide name.
