Skip Navigation Links
Exit Print View
SPARC M5-32 and SPARC M6-32 Servers
Administration Guide
search filter icon
search icon
Document Information
Using This Documentation
Product Notes
Related Documentation
Feedback
Access to Oracle Support
Understanding the System Architecture
Architectural Overview
PDomain Types
Understanding PCIe Device Root Complexes
Control Domain and Reserved Root Complexes
PCIe Communication and Paths
Fully-Populated Default Configuration
Half-Populated Configuration
Understanding PCIe Slot Root Complex Names and Device Paths
PCIe Device Root Complex Failover Behavior
Understanding EMS SAS Paths to the Internal Drives
Drive Access With EMS SAS
EMS and HDD Numbering
SAS Paths From EMS Module to Drives
SAS Pathing Examples
Understanding Internal Drive Device Paths
HDD and SSD Device Path Differences
Understanding DCU0 Drive Device Paths
Understanding DCU1 Drive Device Paths
Understanding DCU2 Drive Device Paths
Understanding DCU3 Drive Device Paths
Understanding Network Port Device Paths
Network Port Numbering
DCU0 Network Port Device Paths
DCU1 Network Port Device Paths
DCU2 Network Port Device Paths
DCU3 Network Port Device Paths
Understanding Configuration Guidelines
SP and SPP Guidelines
PDomain Guidelines
DCU, CMU, and CMP Guidelines
CMU Configuration Examples
Memory (DIMM) Guidelines
Understanding System Administration Resources
Oracle ILOM Overview
Understanding Platform-Specific Oracle ILOM Features
SPARC: Server-Specific and New Oracle ILOM Features and Requirements
Unsupported Oracle OS Features
Unsupported Oracle ILOM Features
Oracle Solaris OS Overview
OpenBoot Overview
Oracle VM Server for SPARC Overview
Multipathing Software Overview
Oracle ILOM Remote System Console Plus Overview
Oracle Hardware Management Pack Overview
Oracle Enterprise Manager Ops Center
Time Synchronization and NTP Service
SNMP Service
Multi-Domain Extensions to ILOM MIBs
Active Directory
LDAP/SSL
Accessing the Server
Establish a Network Management Connection to Oracle ILOM
Logging In to Oracle ILOM
Oracle ILOM Root Password
Log In to Oracle ILOM (Web Interface)
Logging In to Oracle ILOM (CLI)
Log Out of Oracle ILOM
Switch Between the Oracle ILOM CLI and the System Console on a Host
Accessing the ok Prompt
SPARC: OpenBoot ok Prompt
Connect to a PDomain When the System Is Unconfigured and Powered Off
Connect to a PDomain When the Oracle Solaris OS Is Running
Connect to a PDomain When the Oracle Solaris OS Is Unresponsive
Get to the ok Prompt When the Host Is Powered On (Web Interface)
Connect to an LDoms Guest Domain
Redirecting KVMS Devices
Configuring KVMS Settings
Connect to Oracle ILOM Remote System Console Plus
Enable Video Redirection From the Oracle Solaris OS
Configure Multiple Display Devices
Reestablish KVMS Connection to SPPs After a Reboot
Controlling the Server, Domains, and Devices
Controlling the Power State
Power States
Power On
Power Off
Resetting the Server, SP, or Domains
Reset the Server (Oracle Solaris)
Resetting the SP Configuration
Reset a Physical Domain
Managing the Server's Boot Behavior
Change the Default Boot Device (ok Prompt)
Create an OpenBoot Boot Path to a Boot Disk
Enable or Disable Automatic Booting (ok Prompt)
View OpenBoot Parameters
SPARC: OpenBoot Boot Configuration Parameters
SPARC: printenv Output
Booting and Shutting Down the OS
SPARC: Boot Sequence
Boot the OS (Oracle ILOM)
Manually Boot the OS (ok Prompt)
Configuring Oracle ILOM User Accounts and Roles
Managing User Accounts
User Authorization Overview
Understanding Platform and Host-Specific User Role Assignments
Configure User Accounts (CLI)
Configuring User Accounts (SNMP)
Managing User Authentication
User Authentication Overview
Configuring Host Groups to Authenticate User Accounts (CLI)
Configuring Host Groups to Authenticate User Accounts (SNMP)
Configuring the SP Network
Network Resources Overview
Record Network Parameter Values
Configure SP Network Settings
Viewing the Network Configuration
View Configuration Details for the Network
View Configuration Details for SPs and Hosts
Administering SPs
Determine Which SP Is the Active SP
Change the Current Role of the SP Pair
Disable or Re-Enable Network Access to an SP or Host
Managing IP Addresses
Display IP Addresses
Assign an IP Address
Display the MAC Address
Configuring Domain Components
Configuring Physical Domains
Determine PDomain Type
Specifying a PDomain Type
Assign DCUs to a PDomain
Unassign DCUs From a PDomain
Administering DCUs
Determine Current DCU Assignment
Migrate DCUs to a New PDomain (CLI)
Administering CMUs, CMPs, and DIMMs
Display Summary of Installed CMUs
Administering IOUs and PCIe Device Root Complexes
Manage I/O Path Reconfiguration Settings
Identify the Root Complex of a Device
Identifying Domain-Level Commands
PDomain Configuration and Monitoring Commands
Host Power Commands
Boot Mode Commands
Power Management Commands
Single Sign-On Service Network Deployment Commands
Dedicated SP Interconnect Property Commands
FMA Fault Proxying and Reserved Root Complexes
Virtual Keyswitch Property Commands
PDomain Monitoring Commands
Verified Boot Commands
Monitoring the Server
Locating the Server
Locate the Server (Web Interface)
Locate the Server (CLI)
Obtain the Server Serial Number
Viewing Server and Component Information
Viewing System-Level Information
Viewing Individual Component Properties
Monitoring Faults
Discover Faults Using POST
Display Console History
Updating the Firmware
Display the Firmware Version
Firmware Update Overview
Update the Firmware
XSCF and Oracle ILOM Command Comparison
Identifying SP Configuration and Administration Commands
User Account Administration Commands
Network Configuration/Administration Commands
SP Access Control Commands
SP Maintenance Commands
Time Administration Commands
SP Miscellaneous Commands
Identifying Domain Administration Commands
Domain Configuration Commands
Domain Control Commands
Fault Management Commands
Hardware Control Commands
Glossary
Index
The virtual keyswitch can be used to run full POST diagnostics without having to modify the diagnostic property settings. Note that POST diagnostics can take a significant amount of time to run at server reset.
  1. Log in to Oracle ILOM.
    See Log In to Oracle ILOM (Web Interface) .
  2. Set the server to run full POST diagnostics upon server reset.
    -> set /Servers/PDomains/PDomain_x/HOST keyswitch_state=diag
  3. Reset the PDomain.
    -> reset /Servers/PDomains/PDomain_x/HOST
  4. Return to the previous diagnostic settings after running POST.
    -> set /Servers/PDomains/PDomain_x/HOST keyswitch_state=normal
Related Information
