Understanding the System Architecture
Understanding PCIe Device Root Complexes
Control Domain and Reserved Root Complexes
Fully-Populated Default Configuration
Understanding PCIe Slot Root Complex Names and Device Paths
PCIe Device Root Complex Failover Behavior
Understanding EMS SAS Paths to the Internal Drives
SAS Paths From EMS Module to Drives
Understanding Internal Drive Device Paths
HDD and SSD Device Path Differences
Understanding DCU0 Drive Device Paths
Understanding DCU1 Drive Device Paths
Understanding DCU2 Drive Device Paths
Understanding DCU3 Drive Device Paths
Understanding Network Port Device Paths
DCU0 Network Port Device Paths
DCU1 Network Port Device Paths
DCU2 Network Port Device Paths
DCU3 Network Port Device Paths
Understanding Configuration Guidelines
Understanding System Administration Resources
Understanding Platform-Specific Oracle ILOM Features
SPARC: Server-Specific and New Oracle ILOM Features and Requirements
Unsupported Oracle OS Features
Unsupported Oracle ILOM Features
Oracle VM Server for SPARC Overview
Multipathing Software Overview
Oracle ILOM Remote System Console Plus Overview
Oracle Hardware Management Pack Overview
Oracle Enterprise Manager Ops Center
Time Synchronization and NTP Service
Establish a Network Management Connection to Oracle ILOM
Log In to Oracle ILOM (Web Interface)
Logging In to Oracle ILOM (CLI)
Switch Between the Oracle ILOM CLI and the System Console on a Host
Connect to a PDomain When the System Is Unconfigured and Powered Off
Connect to a PDomain When the Oracle Solaris OS Is Running
Connect to a PDomain When the Oracle Solaris OS Is Unresponsive
Get to the ok Prompt When the Host Is Powered On (Web Interface)
Connect to an LDoms Guest Domain
Connect to Oracle ILOM Remote System Console Plus
Enable Video Redirection From the Oracle Solaris OS
Configure Multiple Display Devices
Reestablish KVMS Connection to SPPs After a Reboot
Controlling the Server, Domains, and Devices
Resetting the Server, SP, or Domains
Reset the Server (Oracle Solaris)
Resetting the SP Configuration
Managing the Server's Boot Behavior
Change the Default Boot Device (ok Prompt)
Create an OpenBoot Boot Path to a Boot Disk
Enable or Disable Automatic Booting (ok Prompt)
SPARC: OpenBoot Boot Configuration Parameters
Booting and Shutting Down the OS
Manually Boot the OS (ok Prompt)
Configuring Oracle ILOM User Accounts and Roles
Understanding Platform and Host-Specific User Role Assignments
Configuring User Accounts (SNMP)
Configuring Host Groups to Authenticate User Accounts (CLI)
Configuring Host Groups to Authenticate User Accounts (SNMP)
Record Network Parameter Values
Viewing the Network Configuration
View Configuration Details for the Network
View Configuration Details for SPs and Hosts
Determine Which SP Is the Active SP
Change the Current Role of the SP Pair
Disable or Re-Enable Network Access to an SP or Host
Determine Current DCU Assignment
Migrate DCUs to a New PDomain (CLI)
Administering CMUs, CMPs, and DIMMs
Display Summary of Installed CMUs
Administering IOUs and PCIe Device Root Complexes
Manage I/O Path Reconfiguration Settings
Identify the Root Complex of a Device
Identifying Domain-Level Commands
PDomain Configuration and Monitoring Commands
Single Sign-On Service Network Deployment Commands
Dedicated SP Interconnect Property Commands
FMA Fault Proxying and Reserved Root Complexes
Virtual Keyswitch Property Commands
Locate the Server (Web Interface)
Obtain the Server Serial Number
Viewing Server and Component Information
Viewing System-Level Information
Viewing Individual Component Properties
XSCF and Oracle ILOM Command Comparison
Identifying SP Configuration and Administration Commands
User Account Administration Commands
Network Configuration/Administration Commands
The ILOM MIB files SUN-ILOM-CONTROL-MIB and SUN-HW-CTRL-MIB have been extended to provide a multi-domain version of existing ILOM MIB objects. The MIB files containing the extensions are available under /SP/services/snmp/mibs in the ILOM CLI.
Refer to the Oracle ILOM Protocol Management Reference for SNMP, IPMI, CIM, MS-MAN for examples of the single domain versions of these objects.
In the case of SUN-ILOM-CONTROL-MIB, the extensions correspond to the following multi-domain tables.
ilomCtrlSPARCDiagsTable provides a listing of properties for configuring SPARC-specific diagnostics for each domain.
ilomCtrlSPARCHostControlTable provides a listing of properties for configuring SPARC-specific host software for each domain.
ilomCtrlSPARCBootModeTable provides a listing of properties for configuring SPARC-specific boot mode features for each domain.
ilomCtrlSPARCKeySwitchTable provides a listing of properties for controlling the SPARC-specific virtual key switch for each domain.
ilomCtrlSPARCDomainDCUTable provides a listing of properties for configuring SPARC-specific assigned DCUs for each domain.
ilomCtrlNetInterconnectGlobalCfgTable provides a listing of interconnect configuration entries that can be modified in a multi-domain system.
ilomCtrlNetInterconnectGlobalOperTable provides a listing of interconnect configuration entries that are read-only in a multi-domain system.
In addition, the following SPARC-specific chassis-level diagnostics are available:
ilomCtrlSPARCChassisDiagsMode
ilomCtrlSPARCChassisDiagsTrigger
ilomCtrlSPARCChassisDiagsHWChangeLevel
ilomCtrlSPARCChassisDiagsPowerOnLevel
ilomCtrlSPARCChassisDiagsErrorRestLevel
Refer to the SUN-ILOM-CONTROL-MIB file for detailed information about these objects.
In the case of SUN-HW-CTRL-MIB, the extensions correspond to the following multi-domain tables:
sunHwCtrlDomainPowerMgmtConsumptionTable provides a listing of power consumption entries that can be displayed and modified in a multi-domain system.
sunHwCtrlDomainPowerMgmtBudgetSettingsTable provides a listing of power management budget settings in a multi-domain system.
sunHwCtrlDomainPowerMgmtConsumptionThresholdsTable provides a listing of domain power management consumption entries.
sunHwCtrlTpmTable provides a listing of properties for controlling the access modes of the Trusted Platform Module (TPM) device for each domain.
Refer to the SUN-HW-CTRL-MIB file for detailed information about these objects.
Oracle ILOM Protocol Management Reference for SNMP, IPMI, CIM, WS-MAN at:
