Go to main content
SPARC T5-2 Server Installation Guide
Exit Print View
Updated: February 2017
Install the Server
Use this procedure to install the server chassis, with mounting brackets, into the slide rail assemblies that are mounted to the rack.
Caution
Caution  - This procedure requires a minimum of two people because of the weight of the server. Attempting this procedure alone could result in equipment damage or personal injury.
Caution
Caution  - Always load equipment into a rack from the bottom up so that the rack will not become top-heavy and tip over. Extend the rack's anti-tip bar or anti-tilt legs to prevent the rack from tipping during equipment installation. See Stabilize the Rack for more information.
  1. Push the slide rails into the slide rail assemblies in the rack as far as possible.
  2. Raise the server so that the rear ends of the mounting brackets are aligned with the slide rail assemblies that are mounted in the rack.
    image:Graphic of inserting the server with mounting brackets into the slide rails.
  3. Insert the mounting brackets into the slide rails, and then push the server into the rack until the mounting brackets encounter the slide rail stops (approximately 12 inches, or 30 cm).
    Caution
    Caution  - When inserting the server into the slide rail, ensure that both the top and bottom mounting lips of the mounting brackets are inserted into the slide rail. The server should slide forward and backward easily if correctly installed. If the unit does not slide easily, ensure that each mounting lip is inserted properly. If the mounting brackets are not inserted properly, the unit might fall when it is removed from the rack.
  4. Simultaneously push and hold the green slide rail release buttons on each mounting bracket while you push the server into the rack.
    Continue pushing until the slide rail locks (on the front of the mounting brackets) engage the slide rail assemblies. You will hear an audible click.
    image:Graphic showing the server being push back into the rack.
    Caution
    Caution  - Verify that the server is securely mounted in the rack and that the slide rail locks are engaged with the mounting brackets before continuing.
Related Information
