Go to main content
SPARC and Netra SPARC T5 Series Servers Administration Guide
Exit Print View
Updated: August 2016
Log In to the System Console
  • At the Oracle ILOM prompt, type:
    -> start /HOST/console [-option]
    Are you sure you want to start /HOST/console (y/n) ? y
    Serial console started. To stop, type #.
    where option can be:
    • -f|force – Enables a user with a console (c) role to take the console from any current user and force that user into view mode.
    • -script – Bypasses the prompt for a yes or no confirmation.
    When you reach the system console, you will see the OpenBoot prompt (ok) unless Oracle Solaris is running.
Related Information
