Go to main content
SPARC and Netra SPARC T5 Series Servers Administration Guide
Exit Print View
Updated: August 2016
Reset the Server (Oracle ILOM)
The Oracle ILOM reset command generates a graceful or forced hardware reset of the server. By default, the reset command gracefully resets the server.
Note - By default, the host automatically attempts to boot when the host is reset or powered on. To learn about the parameters that control this action, see Configuring Boot Parameters.
  1. Log in to Oracle ILOM.
    See Log In to Oracle ILOM.
    Note - If you have a modular system, ensure that you are logged in to the desired server module.
  2. Reset the server.
    • Perform a graceful reset.
      -> reset /System
    • If a graceful reset is not possible, perform a forced hardware reset.
      -> reset -force /System
Related Information
