Boot the OS (Oracle ILOM)
By default, the host automatically attempts to
boot when the host is reset or powered on.
- Log
in to Oracle ILOM.
See Log In to Oracle ILOM.
Note - If you have a modular system, ensure that you are logged
in to the desired server module.
- If the OpenBoot parameters are
configured with default values, boot the host using one of these
methods:
Oracle ILOM web interface – In Host Management >
Power Control, select any of the reset, power on, or power cycle
actions, and click Save.
Oracle ILOM CLI – Type:
-> reset /System
Note -
If the OpenBoot parameters are not configured with default values,
when you reset the host, the host might stop at the OpenBoot prompt. To
boot from the OpenBoot prompt, see
Boot the OS Manually
(OpenBoot).
