Go to main content
SPARC and Netra SPARC T5 Series Servers Administration Guide
Exit Print View
Updated: August 2016
Enable or Disable Automatic Booting (OpenBoot)
Use this procedure to configure OpenBoot so that a host reset or power on either attempts to boot automatically, or not. This change is permanent but only takes effect after a host reset.
  1. Obtain the ok prompt.
    See one of these tasks:
  2. Set the OpenBoot auto-boot? parameter.
    • true – (Default) The host automatically attempts to boot from the devices specified in boot-device.
    • false – The host does not automatically boot. You can boot manually.
    For example:
    ok setenv auto-boot? false
  3. Verify the change.
    ok printenv auto-boot?
    auto-boot? =            false
  4. Reset the host.
    ok reset-all
    The host resets. After initialization, the host attempts to boot or not based on your configuration.
Related Information
