Go to main content
SPARC and Netra SPARC T5 Series Servers Administration Guide
Exit Print View
Updated: August 2016
Boot the OS (Oracle ILOM)
By default, the host automatically attempts to boot when the host is reset or powered on.
  1. Log in to Oracle ILOM.
    See Log In to Oracle ILOM.
    Note - If you have a modular system, ensure that you are logged in to the desired server module.
  2. If the OpenBoot parameters are configured with default values, boot the host using one of these methods:
    • Oracle ILOM web interface – In Host Management > Power Control, select any of the reset, power on, or power cycle actions, and click Save.
    • Oracle ILOM CLI – Type:
      -> reset /System
    Note -  If the OpenBoot parameters are not configured with default values, when you reset the host, the host might stop at the OpenBoot prompt. To boot from the OpenBoot prompt, see Boot the OS Manually (OpenBoot).
Related Information
