Use this procedure when the host is powered down and you are logged into Oracle ILOM.
-> set /HOST/bootmode script=”setenv auto-boot? false”
This command temporarily prevents the OS from booting before you obtain the OpenBoot prompt. This change applies only to a single reset and expires in 10 minutes if the power on the host is not reset.
-> reset /System
-> start /HOST/console Are you sure you want to start /HOST/console (y/n)? y Serial console started. To stop, type #.
The server might take several minutes to complete POST and then displays the OpenBoot prompt.
