These topics detail the known issues for Oracle's SPARC T5-1B server module.
When You Create Logical Domains, Some Memory Is Reserved By the Server
rKVMS Does Not Support Redirecting Storage From a SPARC Client (15795058)
Mouse Pointer Is Not Aligned With the Cursor in a Remote Window (15798251)
File Descriptor Leakage in libldom/ldom_xmpp_client.c (15811297)
Spurious sunos.eft.unexpected_telemetry Faults Might be Reported (15820471)
Some USB 3.0 Devices Cause Timeouts and Might Hang the Host (16019551 and 15985683)
Drive OK to Remove LED Might Not Illuminate When a Drive is Unconfigured (16051551)
Unable to Start CLI Shell from CMM to Reach the SP of the Server Module (16093666)
iPOST power-on-reset, error-reset, and hw-change Triggers Do Not Work (16192025)
Oracle ILOM Gets Confused When Multiple ldmd Configuration Files Exist With the Same Name (16239544)
Server Module Might Not Properly Connect to the Sun Blade 6000 Virtualized 40 GbE NEM (16299805)
Infrequent SAS Disconnected command timeout Messages Might Be Displayed (16345218)
CPU Power Management Can Lower Disk IOPS Performance (16355418)
Oracle Solaris 10 OS Does Not Display Some Fault Information (16456603)
