SPARC T5-1B Server Module Product Notes
Exit Print View
Updated: May 2016
Mouse Pointer Is Not Aligned With the Cursor in a Remote Window (15798251)
Note - This issue has been fixed in Oracle Solaris 11 SRU 11.1.9.5.1.
The mouse pointer in the Oracle ILOM video remote console might not track well. The cursor position might be out of sync with the Xorg server on the Oracle Solaris host, a condition that makes mouse navigation and selection difficult.
Workaround A: For a quick but not permanent fix, log in to the Gnome desktop and type this command in a terminal window:
xset m 1 1
This change is not permanent, but immediately makes it easier for you to navigate with the mouse and enables you to perform steps that result in a more permanent change.
If you have problems obtaining a terminal window, try one of these methods:
  • Click the right mouse button. When the desktop pop up is displayed, type: e
  • Use the keyboard to obtain a terminal window by typing Alt-F2. Then type: gnome-terminal
  • Select the desired terminal window as active by typing Alt-Tab.
Workaround B: For a permanent and persistent fix, perform these steps:
  1. Log in to the system on the Gnome desktop.
  2. Choose Launch > System > Preferences > Mouse.
    Alternatively, you can reach this point by typing Alt-F2 and then typing: gnome-mouse-properties
  3. Change the mouse preferences to these values:
    • Pointer Speed Acceleration = Slow
    • Pointer Speed Sensitivity = Low
    • Drag and Drop Threshold = Small
    If you are using the keyboard, navigate by pressing Tab until the desired item is highlighted. For each value, press the left arrow key to move the slides all the way to the left.
    These changes are permanent and persist after screen locks and logging out.
Workaround C: In the Oracle Solaris 11 OS, you can use another method to initially disable problematic mouse acceleration. However, subsequent changes to the mouse acceleration during the Xorg session override the changes made by this method.
  1. Open this file for editing:
    /etc/hal/fdi/preprobe/10osvendor/10-x11-input.fdi
    Ensure that you do not leave any other copies of the file in this directory.
  2. Locate the following lines:
    <merge key="input.x11_options.StreamsModule" type="string">usbms</merge>
    <merge key="input.x11_options.Protocol" type="string">VUID</merge>
  3. Following those lines, add these lines and save the file:
    <merge key="input.x11_options.AccelerationScheme" type="string">none</merge>
    <merge key="input.x11_options.AccelerationNumerator" type="string">1</merge>
    <merge key="input.x11_options.AccelerationDenominator"
    <merge key="input.x11_options.AccelerationThreshold" type="string">1</merge>
  4. Type these Oracle Solaris commands:
    # svcadm restart hal
    # svcadm restart gdm
