man pages section 3: Extended Library Functions, Volume 3
Exit Print View
Updated: July 2014
pool_info(3POOL)
Name
pool_associate, pool_create, pool_destroy, pool_dissociate, pool_info, pool_query_pool_resources - resource pool manipulation functions
Synopsis
cc [ flag… ] file… –lpool [ library… ]
#include <pool.h>
int pool_associate(pool_conf_t *conf,  pool_t *pool,
     pool_resource_t *resource);
pool_t *pool_create(pool_conf_t *conf, const char *name);
int pool_destroy(pool_conf_t *conf, pool_t *pool);
int pool_dissociate(pool_conf_t *conf, pool_t *pool,
const char *pool_info(pool_conf_t *conf, pool_t *pool,
     int flags);
pool_resource_t **pool_query_pool_resources(pool_conf_t *conf,
     pool_t *pool, uint_t *nelem, pool_value_t **properties);
Description
These functions provide mechanisms for constructing and modifying pools entries within a target pools configuration. The conf argument for each function refers to the target configuration to which the operation applies.
The pool_associate() function associates the specified resource with pool. A resource can be associated with multiple pools at the same time. Any resource of this type that was formerly associated with this pool is no longer associated with the pool. The new association replaces the earlier one.
The pool_create() function creates a new pool with the supplied name with its default properties initialized, and associated with the default resource of each type.
The pool_destroy function() destroys the given pool association. Associated resources are not modified.
The pool_dissociate() function removes the association between the given resource and pool. On successful completion, the pool is associated with the default resource of the same type.
The pool_info() function returns a string describing the given pool. The string is allocated with malloc(3C). The caller is reponsible for freeing the returned string. If the flags option is non-zero, the string returned also describes the associated resources of the pool.
The pool_query_pool_resources() function returns a null-terminated array of resources currently associated with the pool that match the given list of properties. The return value must be freed by the caller. The nelem argument is set to be the length of the array returned.
Return Values
Upon successful completion, pool_create() returns a new initialized pool. Otherwise it returns NULL and pool_error(3POOL) returns the pool-specific error value.
Upon successful completion, pool_associate(), pool_destroy(), and pool_dissociate() return 0. Otherwise, they return -1 and pool_error() returns the pool-specific error value.
Upon successful completion, pool_info() returns a string describing the given pool. Otherwise it returns NULL and pool_error() returns the pool-specific error value.
Upon successful completion, pool_query_pool_resources() returns a null-terminated array of resources. Otherwise it returns NULL and pool_error() returns the pool-specific error value.
Errors
The pool_create() function will fail if:
POE_BADPARAM
The supplied configuration's status is not POF_VALID or name is already in use.
POE_SYSTEM
A system error has occurred. Check the system error code for more details.
POE_INVALID_CONF
The pool element could not be created because the configuration would be invalid.
POE_PUTPROP
One of the supplied properties could not be set.
The pool_destroy() function will fail if:
POE_BADPARAM
The supplied configuration's status is not POF_VALID.
The pool_associate() function will fail if:
POE_BADPARAM
The supplied configuration's status is not POF_VALID or the parameters are supplied from a different configuration.
POE_SYSTEM
The pool_disassociate() function will fail if:
POE_BADPARAM
POE_INVALID_CONF
No resources could be located for the supplied configuration or the supplied configuration is not valid (for example, more than one default for a resource type was found.)
POE_SYSTEM
The pool_info() function will fail if:
POE_BADPARAM
The supplied configuration's status is not POF_VALID or the flags paramter is neither 0 or 1.
POE_INVALID_CONF
The configuration is invalid.
POE_SYSTEM
The pool_query_pool_resources() function will fail if:
POE_BADPARAM
POE_INVALID_CONF
POE_SYSTEM
Usage
Pool names are unique across pools in a given configuration file. It is an error to attempt to create a pool with a name that is currently used by another pool within the same configuration.
Attributes
ATTRIBUTE TYPE
ATTRIBUTE VALUE
CSI
Enabled
Interface Stability
Uncommitted
MT-Level
Safe
See also
libpool(3LIB), pool_error(3POOL), attributes(5)
