man pages section 3: Extended Library Functions, Volume 3
Exit Print View
Updated: July 2014
ptree_add_prop(3PICLTREE)
Name
ptree_add_prop, ptree_delete_prop - add or delete a property
Synopsis
cc [ flag... ] file... –lpicltree [ library... ]
#include <picltree.h>
int ptree_add_prop(picl_nodehdl_t nodeh, picl_prophdl_t proph);
int ptree_delete_prop(picl_prophdl_t proph);
Description
The ptree_add_prop() function adds the property specified by the handle proph to the list of properties of the node specified by handle nodeh.
The ptree_delete_prop() function deletes the property from the property list of the node. For a table property, the entire table is deleted.
Return Values
Upon successful completion, 0 is returned. On failure, a non-negative integer is returned to indicate an error.
PICL_STALEHANDLE is returned if the handle is no longer valid. This occurs if the PICL tree was refreshed or reinitialized.
PICL_INVALIDHANDLE is returned if the specified handle never existed.
Errors
PICL_NOTTABLE
Not a table
PICL_NOTPROP
Not a property
PICL_INVALIDHANDLE
Invalid handle
PICL_STALEHANDLE
Stale handle
PICL_PROPEXISTS
Property already exists
PICL_FAILURE
General system failure
Attributes
ATTRIBUTE TYPE
ATTRIBUTE VALUE
Interface Stability
Committed
MT-Level
MT-Safe
See also
ptree_create_prop(3PICLTREE), attributes(5)
