cc [ flag... ] file... –lpicltree [ library... ] #include <picltree.h> int ptree_create_and_add_node(picl_nodehdl_t parh, const char *name, const char *classname, picl_nodehdl_t *nodeh);
The ptree_create_and_add_node() function creates a node with the name and PICL class specified by name and classname respectively. It then adds the node as a a child to the node specified by parh. The handle of the new node is returned in nodeh.
Upon successful completion, 0 is returned. On failure, a non-negative integer is returned to indicate an error.
PICL_STALEHANDLE is returned if the handle is no longer valid. This occurs if the PICL tree was refreshed or reinitialized.
PICL_INVALIDHANDLE is returned if the specified handle never existed.
Invalid argument
Value exceeds maximum size
Property version not supported
Attempting to destroy before delete
Not a node
Invalid handle
Stale handle
General system failure
ptree_create_node(3PICLTREE), ptree_add_node(3PICLTREE), attributes(5)
