man pages section 3: Extended Library Functions, Volume 3
Exit Print View
Updated: July 2014
setprojent(3PROJECT)
Name
getprojent, getprojbyname, getprojbyid, getdefaultproj, inproj, getprojidbyname, setprojent, endprojent, fgetprojent - project database entry operations
Synopsis
cc [ flag... ] file... −lproject [ library... ]
#include <project.h>
struct project *getprojent(struct project *proj, void *buffer,
     size_t bufsize);
struct project *getprojbyname(const char *name,
     struct project *proj, void *buffer, size_t bufsize);
struct project *getprojbyid(projid_t projid,
struct project *getdefaultproj(const char *username,
int inproj(const char *username, const char *projname,
projid_t getprojidbyname(const char *name);
void setprojent(void);
void endprojent(void);
struct project *fgetprojent(FILE *f, struct project *proj,
Description
These functions are used to obtain entries describing user projects. Entries can come from any of the sources for a project specified in the /etc/nsswitch.conf file (see nsswitch.conf (4)).
The setprojent(), getprojent(), and endprojent() functions are used to enumerate project entries from the database.
The setprojent() function effectively rewinds the project database to allow repeated searches. It sets (or resets) the enumeration to the beginning of the set of project entries. This function should be called before the first call to getprojent().
The getprojent() function returns a pointer to a structure containing the broken-out fields of an entry in the project database. When first called, getprojent() returns a pointer to a project structure containing the first project structure in the project database. Successive calls can be used to read the entire database.
The endprojent() function closes the project database and deallocates resources when processing is complete. It is permissible, though possibly less efficient, for the process to call more project functions after calling endprojent().
The getprojbyname() function searches the project database for an entry with the project name specified by the character string name.
The getprojbyid() function searches the project database for an entry with the (numeric) project ID specified by projid.
The getdefaultproj() function behaves as follows:
  • It searches for a named project defined by the “project” keyword in the user's user_attr entry. If no match is found, or if the user is excluded from that project, it proceeds to the next search. Otherwise, the project pointer is returned.
  • It searches for a project with a naming pattern of “user.user_name” where user_name is the user's login name. If no match is found, or if the user is excluded from that project, it proceeds to the next search. Otherwise, the project pointer is returned.
  • It searches for a project with a naming pattern of “group.group_name” where group_name is the user's primary group name. If no match is found, or if the user is excluded from that project, it proceeds to the next search. Otherwise, the project pointer is returned.
  • It searches for a project named “default”. If no match is found, or if the user is excluded from that project, it returns NULL. Otherwise, the project pointer is returned.
The inproj() function checks if the user specified by username is able to use the project specified by projname. It returns 1 if the project is the user's default project, the user is not explicitly excluded from that project's users list, and the user is not explicitly excluded from that project's groups list. It also returns 1 if the project is a normal project, the user is not explicitly excluded from and is explicitly included in that project's users list, and the user is not explicitly excluded from and is explicitly included in that project's groups list. It returns 0 for all other cases.
A user is considered explicitly excluded from a project's users list if there exists a “!*” or a “!user_name” token, where user_name is the user's login name.
A user is considered explicitly included in a project's users list if there exists a “*” or a “user_name” token, where user_name is the user's login name.
A user is considered explicitly excluded in a project's groups list if there exists a “!*” or a “!group_name” token, where group_name is the user's primary group name or the name of a group to which the user belongs.
A user is considered explicitly included in a project's groups list if there exists a “*” or a “group_name” token, where group_name is the user's primary group name or the name of a group to which the user belongs.
The getprojidbyname() function searches the project database for an entry with the project name specified by the character string name. This function returns the project ID if the requested entry is found; otherwise it returns −1.
The fgetprojent() function, unlike the other functions described above, does not use nsswitch.conf; it reads and parses the next line from the stream f, which is assumed to have the format of the project(4) file. This function returns the same values as getprojent().
The getprojent(), getprojbyname(), getprojbyid(), getdefaultproj(), and inproj() functions are reentrant interfaces for operations with the project database. These functions use buffers supplied by the caller to store returned results and are safe for use in both single-threaded and multithreaded applications.
Reentrant interfaces require the additional arguments proj, buffer, and bufsize. The proj argument must be a pointer to a struct project structure allocated by the caller. On successful completion, the function returns the project entry in this structure. Storage referenced by the project structure is allocated from the memory provided with the buffer argument, which is bufsize bytes in size. The content of the memory buffer could be lost in cases when these functions return errors.
For enumeration in multithreaded applications, the position within the enumeration is a process-wide property shared by all threads. The setprojent() function can be used in a multithreaded application but resets the enumeration position for all threads. If multiple threads interleave calls to getprojent(), the threads will enumerate disjoint subsets of the project database. The inproj(), getprojbyname(), getprojbyid(), and getdefaultproj() functions leave the enumeration position in an indeterminate state.
Return Values
Project entries are represented by the struct project structure defined in <project.h>.
struct project {
    char      *pj_name;     /* name of the project */
    projid_t  pj_projid;    /* numerical project id */
    char      *pj_comment;  /* project comment */
    char      **pj_users;   /* vector of pointers to
                               project user names */
    char      **pj_groups;  /* vector of pointers to
                               project group names */
    char      *pj_attr;     /* project attributes */
The getprojbyname() and getprojbyid() functions each return a pointer to a struct project if they successfully locate the requested entry; otherwise they return NULL.
The getprojent() function returns a pointer to a struct project if it successfully enumerates an entry; otherwise it returns NULL, indicating the end of the enumeration.
The getprojidbyname() function returns the project ID if the requsted entry is found; otherwise it returns −1 and sets errno to indicate the error.
When the pointer returned by the reentrant functions getprojbyname(), getprojbyid(), and getprojent() is non-null, it is always equal to the proj pointer that was supplied by the caller.
Upon failure, NULL is returned and errno is set to indicate the error.
Errors
The getprojent(), getprojbyname(), getprojbyid(), inproj(), getprojidbyname(), fgetprojent(), and getdefaultproj() functions will fail if:
EINTR
A signal was caught during the operation.
EIO
An I/O error has occurred.
EMFILE
There are OPEN_MAX file descriptors currently open in the calling process.
ENFILE
The maximum allowable number of files is currently open in the system.
ERANGE
Insufficient storage was supplied by buffer and bufsize to contain the data to be referenced by the resulting project structure.
These functions can also fail if the name service switch does not specify valid project(4) name service sources. In the case of an incompletely configurated name service switch configuration, getprojbyid() and other functions can return error values other than those documented above. These conditions usually occur when the nsswitch.conf file indicates that one or more name services is providing entries for the project database when that name service does not actually make a project table available.
Usage
When compiling multithreaded applications, see Intro(3), Notes On Multithreaded Applications.
Use of the enumeration interface getprojent() is discouraged. Enumeration is supported for the project file, NIS, and LDAP but in general is not efficient. The semantics of enumeration are discussed further in nsswitch.conf(4).
Attributes
ATTRIBUTE TYPE
ATTRIBUTE VALUE
Interface Stability
Committed
MT-Level
See Description.
See also
Intro(3), libproject(3LIB) , project_walk(3PROJECT), sysconf (3C), nsswitch.conf(4), project (4), attributes(5)
