Chapter 3 Statistics and Datasets
Determining the impact of a dynamic statistic
Capacity: Capacity Percent Used
Capacity System Pool Bytes Used
Capacity: System Pool Bytes Used
Capacity System Pool Percent Used
Data Movement NDMP Bytes Statistics
Data Movement: NDMP Bytes Statistics
Data Movement NDMP Operations Statistics
Data Movement: NDMP Operations Statistics
Data Movement Replication Bytes
Data Movement: Replication Bytes
Data Movement Replication Operations
Data Movement: Replication Operations
Data Movement Shadow Migration Bytes
Data Movement: Shadow Migration Bytes
Data Movement Shadow Migration Ops
Data Movement: Shadow Migration Ops
Data Movement Shadow Migration Requests
Data Movement: Shadow Migration Requests
Protocol Fibre Channel Operations
Protocol: Fibre Channel Operations
Protocol: HTTP/WebDAV Requests
Data Movement NDMP Bytes Transferred to/from Disk
Data Movement: NDMP Bytes Transferred to/from Disk
Data Movement NDMP Bytes Transferred to/from Tape
Data Movement: NDMP Bytes Transferred to/from Tape
Data Movement NDMP File System Operations
Data Movement: NDMP File System Operations
Data Movement Replication Latencies
Data Movement: Replication Latencies
Disk ZFS Logical I/O Operations
Disk: ZFS Logical I/O Operations
Memory Kernel Memory Lost to Fragmentation
Memory: Kernel Memory Lost to Fragmentation
This statistic shows the used percentage of the system pool capacity based on the raw pool size. It is used as a threshold alert and cannot be displayed in a graph. Unlike other statistics, it is updated every five minutes instead of every second.
To create this capacity alert in the CLI, navigate to the analytics and datasets context. If using worksheets, navigate to analytics, the desired worksheet, and then the dataset context. For datasets, use the "create" command. For worksheets, use the "set name" command. Below, the "\" character denotes a line break.
clownfish:> analytics clownfish:analytics> datasets clownfish:analytics datasets> create syscap.percentused
OR
clownfish:> analytics clownfish:analytics> worksheets clownfish:analytics worksheets> select worksheet-000 clownfish:analytics worksheets worksheet-000> dataset clownfish:analytics worksheets worksheet-000 dataset \ (uncommitted)> set name="syscap.percentused" clownfish:analytics worksheets worksheet-000 dataset \ (uncommitted)> commit
This statistic can be used as a threshold alert for the used system pool capacity in a percentage. If the threshold is exceeded and the alert is triggered, you can mitigate the situation before the system pool becomes too full and performance is impacted.
None.
See Capacity: System pool bytes used for a threshold alert, in bytes, for the system pool used capacity.
