Chapter 3 Statistics and Datasets
Determining the impact of a dynamic statistic
Capacity: Capacity Percent Used
Capacity System Pool Bytes Used
Capacity: System Pool Bytes Used
Capacity System Pool Percent Used
Capacity: System Pool Percent Used
Data Movement NDMP Bytes Statistics
Data Movement: NDMP Bytes Statistics
Data Movement NDMP Operations Statistics
Data Movement: NDMP Operations Statistics
Data Movement Replication Bytes
Data Movement: Replication Bytes
Data Movement Replication Operations
Data Movement: Replication Operations
Data Movement Shadow Migration Bytes
Data Movement: Shadow Migration Bytes
Data Movement Shadow Migration Ops
Data Movement: Shadow Migration Ops
Data Movement Shadow Migration Requests
Data Movement: Shadow Migration Requests
Protocol Fibre Channel Operations
Protocol: Fibre Channel Operations
Protocol: HTTP/WebDAV Requests
Data Movement NDMP Bytes Transferred to/from Disk
Data Movement: NDMP Bytes Transferred to/from Disk
Data Movement NDMP Bytes Transferred to/from Tape
Data Movement: NDMP Bytes Transferred to/from Tape
Data Movement NDMP File System Operations
Data Movement: NDMP File System Operations
Data Movement Replication Latencies
Data Movement: Replication Latencies
Disk ZFS Logical I/O Operations
Disk: ZFS Logical I/O Operations
Memory Kernel Memory Lost to Fragmentation
Memory: Kernel Memory Lost to Fragmentation
This statistic shows requests made by NSCD (Name Service Cache Daemon) to back-end sources, such as DNS, NIS, etc.
An understanding of operating system internals may be required to properly interpret this statistic.
It may be useful to check the latency breakdown if long latencies were experienced on the appliance, especially during administrative logins. The breakdowns for the database name and source will show what the latency is for, and which remote server is responsible.
