Skip Navigation Links
Exit Print View
Sun Ethernet Fabric Operating System
LA Administration Guide
search filter icon
search icon
Document Information
Using This Documentation
Product Notes
Related Documentation
Acronyms and Abbreviations
CLI Command Modes
Feedback
Support and Accessibility
LA Overview
Protocol Description
Configuring LA
LA Topology Example
Configuration Guidelines
Default Settings
Enable Link Aggregation
Configuring Port-Channel Interfaces
Configure Port-Channel Interfaces
Configure the LACP Port Priority
Configure the LACP System Priority
Configure Port Channel Load Balancing
Configure the LACP System Identifier
Configure the LACP Port Identifier
Setting the MTU Value
Set the MTU Value on one or More Ports
Set the MTU Value of the Port Channel
Configure the LACP Wait Time
Configure the LACP Time-Out Value
Display the LACP Status
Interaction Between LA and VLANs
Default Settings
SEFOS is shipped with the following default settings:
Feature
Default Setting
Port channel
Disabled
Channel groups
None
LACP system priority
0x8000 or 32768
Load balancing
Source and destination (MAC address based)
LACP wait time
2
LACP timeout
Long (The LACP PDU is sent every 30 seconds, and the LACP timeout value is sent every 90 seconds.)
MAC selection
Dynamic (The port-channel MAC address is the address of an active port.)
