Configuring Port-Channel Interfaces
Configure Port-Channel Interfaces
Configure the LACP Port Priority
Configure the LACP System Priority
Configure Port Channel Load Balancing
Configure the LACP System Identifier
Set the MTU Value on one or More Ports
Set the MTU Value of the Port Channel
In the following procedure, ports 0/1, 0/2, and 0/3 are part of the LA.
SEFOS# show etherchannel 1 detail
The following output has been truncated for readability.
LACP Port Admin Oper Port Port
Port State Priority Key Key Number State
Ex0/1 Bundle 128 1 1 0x1 0xbe
Ex0/2 Bundle 128 1 1 0x2 0xbe
Ex0/3 Standby 128 1 1 0x3 0xa2
Note - Before you configure the LACP port identifier, note that the extreme-ethernet port, 0/3, in switch A and switch B are standby ports.
SEFOS(config)# interface extreme-ethernet 0/3 SEFOS(config-if)# lacp port-identifier 1
The output has been truncated for readability.
SEFOS# show etherchannel detail
Ex0/1 Bundle 128 1 1 0x1 0xbc
Ex0/2 Standby 128 1 1 0x2 0xa0
Ex0/3 Bundle 128 1 1 0x3 0xbc
Note - After you configure the LACP port identifier, note that the extreme-ethernet port, 0/3, in switch A is brought up in the bundle state.
