Skip Navigation Links
Exit Print View
Sun Ethernet Fabric Operating System
LA Administration Guide
search filter icon
search icon
Document Information
Using This Documentation
Product Notes
Related Documentation
Acronyms and Abbreviations
CLI Command Modes
Feedback
Support and Accessibility
LA Overview
Protocol Description
Configuring LA
LA Topology Example
Configuration Guidelines
Default Settings
Enable Link Aggregation
Configuring Port-Channel Interfaces
Configure Port-Channel Interfaces
Configure the LACP Port Priority
Configure the LACP System Priority
Configure Port Channel Load Balancing
Configure the LACP System Identifier
Configure the LACP Port Identifier
Setting the MTU Value
Set the MTU Value on one or More Ports
Set the MTU Value of the Port Channel
Configure the LACP Wait Time
Configure the LACP Time-Out Value
Display the LACP Status
Interaction Between LA and VLANs
In the following procedure, ports 0/1, 0/2, and 0/3 are part of the LA. Unless otherwise noted, you must run all of the commands in the following procedure on both switches.
  1. Enable port channeling.
    SEFOS# configure terminal
    SEFOS(config)# set port-channel enable
  2. Create the port channel (1 in this example).
    SEFOS(config)# interface port-channel 1
    SEFOS(config-if)# no shutdown
    SEFOS(config)# end
  3. Configure the LACP system identifier.
    SEFOS(config)# lacp system-identifier 00:55:44:33:22:11
    SEFOS(config)# end
  4. Review the etherchannel information to ensure that the port channel system identifier has been set.
    The output has been truncated for readability.
    SEFOS# show etherchannel detail
    Port-channel System Identifier is  00:55:44:33:22:11
