Skip Navigation Links
Exit Print View
Sun Ethernet Fabric Operating System
LA Administration Guide
search filter icon
search icon
Document Information
Using This Documentation
Product Notes
Related Documentation
Acronyms and Abbreviations
CLI Command Modes
Feedback
Support and Accessibility
LA Overview
Protocol Description
Configuring LA
LA Topology Example
Configuration Guidelines
Default Settings
Enable Link Aggregation
Configuring Port-Channel Interfaces
Configure Port-Channel Interfaces
Configure the LACP Port Priority
Configure the LACP System Priority
Configure Port Channel Load Balancing
Configure the LACP System Identifier
Configure the LACP Port Identifier
Setting the MTU Value
Set the MTU Value on one or More Ports
Set the MTU Value of the Port Channel
Configure the LACP Wait Time
Configure the LACP Time-Out Value
Display the LACP Status
Interaction Between LA and VLANs
LA is disabled by default. See LA Topology Example for the topology of this procedure.
  1. In both switches, enable LA.
    SEFOS# configure terminal
    SEFOS(config)# set port-channel enable
    SEFOS(config)# end
  2. View the etherchannel information.
    SEFOS# show etherchannel summary
    The output in switch A and switch B should be:
    Port-channel Module Admin Status is enabled
    Port-channel Module Oper Status is enabled
    Port-channel System Identifier is  00:14:4f:6c:68:2f
    Note - To shut down the entire LA module, type the shutdown port-channel command.
