Skip Navigation Links
Exit Print View
Sun Ethernet Fabric Operating System
LA Administration Guide
search filter icon
search icon
Document Information
Using This Documentation
Product Notes
Related Documentation
Acronyms and Abbreviations
CLI Command Modes
Feedback
Support and Accessibility
LA Overview
Protocol Description
Configuring LA
LA Topology Example
Configuration Guidelines
Default Settings
Enable Link Aggregation
Configuring Port-Channel Interfaces
Configure Port-Channel Interfaces
Configure the LACP Port Priority
Configure the LACP System Priority
Configure Port Channel Load Balancing
Configure the LACP System Identifier
Configure the LACP Port Identifier
Setting the MTU Value
Set the MTU Value on one or More Ports
Set the MTU Value of the Port Channel
Configure the LACP Wait Time
Configure the LACP Time-Out Value
Display the LACP Status
Interaction Between LA and VLANs
You can display a detailed report or a summary of the LACP status by using the show command. You can view specific information about the load-balancing and frame-distribution schemes, specific information about the individual ports in the port channel, and general information about the port channel settings.
  1. Get specific details.
    SEFOS# show etherchannel 1 detail
    SEFOS(config)# interface extreme-ethernet 0/1
  2. View specific LACP information, such as traffic counters and neighbor information.
    SEFOS# show lacp neighbor detail
