Skip Navigation Links
Exit Print View
Sun Ethernet Fabric Operating System
PIMv6 Administration Guide
PDF
search filter icon
search icon
Document Information
Using This Documentation
Product Notes
Related Documentation
Acronyms and Abbreviations
CLI Command Modes
Feedback
Support and Accessibility
SEFOS PIMv6 Overview
Supported Features
Protocol Description
Default Settings
Topology Example
Configuring the Topology Example
Enable IPv6 Support and Assign IPv6 Addresses
Configure PIMv6 in Router A
Configure PIMv6 in Router B
Global Configurations
Enable PIMv6
Configure the Group and Source Thresholds
Configure the SPT Switching Period
Configure the Rendezvous Point Threshold
Configure the RP Switch Period
Configure the regstop Rate Limit
Configure the PMBR Status
Configuring PIMv6 on an Interface
Associate the PIMv6 Component to an Interface
Configure the Query-Interval Value
Configure the DR Priority Value
Configure the Override Interval
Configure the LAN Delay
Configure the LAN Prune Delay
Configure the BSR Candidate
Configure the Message Interval
Configuring the PIMv6 Component
Create a PIMv6 Component
Set the Mode for the PIMv6 Component
Configure the RP-Candidate Hold Time
Configure the RP-Candidate Address
Configure the RP Static Address
Create an RP-Set Table
Create a PIMv6 Neighbor
Create Multicast Routes
Product Notes
For late-breaking information and known issues about the following products, refer to the product notes at:
Sun Blade 6000 Ethernet Switched NEM 24p 10GbE:
http://www.oracle.com/pls/topic/lookup?ctx=SB6K-24p-10GbE
Sun Network 10GbE Switch 72p:
http://www.oracle.com/pls/topic/lookup?ctx=SN-10GbE-72p
