| Skip Navigation Links | |
| Exit Print View | |
Sun Ethernet Fabric Operating System PIMv6 Administration Guide |
Configuring the Topology Example
Enable IPv6 Support and Assign IPv6 Addresses
Configure the Group and Source Thresholds
Configure the SPT Switching Period
Configure the Rendezvous Point Threshold
Configure the RP Switch Period
Configure the regstop Rate Limit
Configuring PIMv6 on an Interface
Associate the PIMv6 Component to an Interface
Configure the Query-Interval Value
Configure the DR Priority Value
Configure the Override Interval
Configure the Message Interval
Configuring the PIMv6 Component
Set the Mode for the PIMv6 Component
Configure the RP-Candidate Address
The hold-time value is the amount of time the candidate RP advertisement is valid. When you configure the RP-candidate hold time, you set the hold time of the component when it is a candidate RP in the local domain. The mode must already be set to sparse.
SEFOS(config)# interface vlan 7 SEFOS(config-if)# ipv6 pim componentId 1 SEFOS(config-if)# end
SEFOS(config)# ip pim component 1
SEFOS(pim-comp)# rp-candidate holdtime 30 SEFOS(pim-comp)# end
SEFOS# show ipv6 pim component 1 PIM Component Information --------------------------- Component-Id: 1 PIM Mode: sparse, PIM Version: 2 Elected BSR: :: Candidate RP Holdtime: 30
