Skip Navigation Links
Exit Print View
Sun Ethernet Fabric Operating System
PIMv6 Administration Guide
search filter icon
search icon
Document Information
Using This Documentation
Product Notes
Related Documentation
Acronyms and Abbreviations
CLI Command Modes
Feedback
Support and Accessibility
SEFOS PIMv6 Overview
Supported Features
Protocol Description
Default Settings
Topology Example
Configuring the Topology Example
Enable IPv6 Support and Assign IPv6 Addresses
Configure PIMv6 in Router A
Configure PIMv6 in Router B
Global Configurations
Enable PIMv6
Configure the Group and Source Thresholds
Configure the SPT Switching Period
Configure the Rendezvous Point Threshold
Configure the RP Switch Period
Configure the regstop Rate Limit
Configure the PMBR Status
Configuring PIMv6 on an Interface
Associate the PIMv6 Component to an Interface
Configure the Query-Interval Value
Configure the DR Priority Value
Configure the Override Interval
Configure the LAN Delay
Configure the LAN Prune Delay
Configure the BSR Candidate
Configure the Message Interval
Configuring the PIMv6 Component
Create a PIMv6 Component
Set the Mode for the PIMv6 Component
Configure the RP-Candidate Hold Time
Configure the RP-Candidate Address
Configure the RP Static Address
Create an RP-Set Table
Create a PIMv6 Neighbor
Create Multicast Routes
Static configuration allows additional structuring of the multicast traffic by directing the multicast join or prune messages to statically configured RPs.
  1. Associate the VLAN 7 interface with the PIMv6 component 1.
    SEFOS(config)# interface vlan 7
    SEFOS(config-if)# ipv6 pim componentId 1
    SEFOS(config-if)# end
  2. Enable the static-RP configuration for the router.
    SEFOS# configure terminal
    SEFOS(config)# set ip pim static-rp enable
  3. Enter the PIMv6 component mode for the component (2 in this example).
    SEFOS(config)# ip pim component 2
  4. Set the RP static RP address (7777::11) with a mask length of 128 for group ff02::e001:1 in PIMv6 component 1.
    This step uses the following parameters:
    • RP address: 7777::11
    • Mask length: 128
    • Group address: ff02::e001:1
    SEFOS(pim-comp)# ipv6 pim rp-static rp-address ff02::e001:1 128 7777::11
    SEFOS(pim-comp)# end
  5. Review the RP static RP address.
    SEFOS# show ipv6 pim rp-static 2
    Static-RP Enabled
    CompId    GroupAddress/PrefixLength       RPAddress
         2             ff02::e001:1/128           7777::11
