Skip Navigation Links | |
Exit Print View | |
Sun Ethernet Fabric Operating System VRRP Administration Guide |
Create VRRP Instance Over an Interface
Configure Additional Associated IP Addresses to a VRRP Instance
See the first figure in VRRP Topology for the topology in this example. You can configure VRRP master router to send an advertisement packet at regular intervals to convey to the backup routers that the master is alive. By default, this interval is 1 second. You can configure this value in the range 1 to 255. In this example, you set the advertisement interval to 5 seconds on VLAN 2.
SEFOS# configure terminal SEFOS(config)# router vrrp SEFOS(config-vrrp)# interface vlan 2 SEFOS(config-vrrp-if)# vrrp 1 timer 5 SEFOS(config-vrrp-if)# end
SEFOS# show vrrp interface vlan 2 detail vlan2 - vrID 1 --------------- State is Master Virtual IP address is 12.0.0.5 Virtual MAC address is 00:00:5e:00:01:01 Master router is 12.0.0.5 Associated IpAddresses : ---------------------- 12.0.0.5 12.0.0.6 Advertise time is 5 secs Current priority is 200 Configured priority is 200, may preempt Configured Authentication Authentication key is text1 Accept Mode Disabled
SEFOS# show vrrp interface vlan 2 detail vlan2 - vrID 1 --------------- State is Backup Virtual IP address is 12.0.0.5 Virtual MAC address is 00:00:5e:00:01:01 Master router is 12.0.0.5 Associated IpAddresses : ---------------------- 12.0.0.5 12.0.0.6 Advertise time is 5 secs Current priority is 150 Configured priority is 150, may preempt Configured Authentication Authentication key is text1 Accept Mode Disabled
